Realtor Rear Tires: $75
Brand new Stock YFZ450 tires:$60
Front Brake Calipers with Stainless Steel Lines:$100
2 complete front brake setups w/master Cylinders: $90 each
Clucth Cover: $45
Brand NEW Clutch Cover Powdercoated Candy Blue:$100
Rear Brake Line, Master Cylinder and Pedal: $50
2 complete Rear brake setups with parking brake block off: $85 each
Stock rear Shock:$ 75
4 gas tanks: ??
Front brake master cylinder: $30
Renthal bars with Scott grips: $45
2 sets of stock Cylinders:??
2 thumb Throttles: $50 each
Blaster Rear Hubs: $40
4 sets of Stock front hubs with rotor:$40 each set
Motor Mounts: $20
Stock Heel Gaurds:$30
Nickle FMF Fatties:$200
Black FMF Fatties:$150
Chrome FMF SST with powercore2:$ 300
Polished DG Nerfs:$90
ArmadilloBelly Skid plate: $50
Full Bottom GYTR skid plate set:$125
Stock Swinger:$40
Yellow Stock Shocks:$40
5 stock Radiator:???
04 frame with tittle: $400
Lonestar +4 Chrome Axcalibar Axle:$200
Works Tripple Rate with Remote Rezzies: $300
Axis Rear 8 way adjustable shock with remote Rezz like new: $500
2 steering stems:$40 each
Roll Design lobo +2 +1 arms (comes with tierods and spindles:$450
2 sets of Boyseen Rad vavles with cages:$100 each
Complete Tranny out 05:$ 170
Complete Clutch basket with Heavy Duty EBC clutch setup:$85
Mint Casses:$200
Complete CDI, Wiring harness, Coil:$100
Stator:$60
Flywheel:$50
Lonestar +2 Chrome Roundhouse Swingarm with Carrier and linkage:$500
Full Set of Beadlocks with Holeshot MX6 tires:$350
I have pics of everything.........
Edited by ellison445
Your parting out your shee arent you. Whats up you cant return any calls? :thanks:LOL
Jeff how many watts is the stator ? and do you have and aftermarket lights?
Hell no!!! Thats just extra parts I have laying around... I lost my phone and your number!! Call me and leave your number this time :biggrin: :biggrin:
Clucth Cover: $45
4 gas tanks: ??
Motor Mounts: $20
Stock Swinger:$40
Mint Casses:$200
Stator:$60
Flywheel:$50
Are the cylinders standard bore? How much and would you sell a right hand or only pairs?
Stock shock is good not blown.
Damn dude, what a mess. Is the stock rear shock any count? not blown or anything?
not looking to seperate the beadlocks
how much for just front wheels???
I will sell the axle with no hubs, but the carrier stays with the swinger..
hi, would you sell just the axle with no hubs and the carrier for 200$ shipped?
that would be fine but i am planning on putting the axle in a blaster and some say you need to swap the carrier some say you dont. if you can give me some solid information on using the axle in my blaster ill consider it. thanks
