mofoka Posted July 17, 2008 Report Posted July 17, 2008 One float is not moving when I push the throttle. I have stock carbs with TORS. I can move the float with a screwdriver so it isn't stuck.... Any idea's on how to get it going again? Do I need to open up the TORS system? Quote
Face Posted July 17, 2008 Report Posted July 17, 2008 Just take TORS off, then see about your problem! Quote
hyperlite33 Posted July 17, 2008 Report Posted July 17, 2008 One float is not moving when I push the throttle. I have stock carbs with TORS. I can move the float with a screwdriver so it isn't stuck.... Any idea's on how to get it going again? Do I need to open up the TORS system? Your talking about the slides right and not the floats? Quote
mofoka Posted July 17, 2008 Author Report Posted July 17, 2008 Your talking about the slides right and not the floats? ..... I thought it was the Float... it is the cylinder that you see by looking in the carb from the air box. When I push the throttle it moves up on the right side but not the left. Quote
hyperlite33 Posted July 17, 2008 Report Posted July 17, 2008 ..... I thought it was the Float... it is the cylinder that you see by looking in the carb from the air box. When I push the throttle it moves up on the right side but not the left. That is the slide your looking at in the throat of the carb...I have never dealt with the TORS so I can't help you, but I would highly suggest getting the TORS removed to save on many headaches now and in the future! Quote
mofoka Posted July 17, 2008 Author Report Posted July 17, 2008 That is the slide your looking at in the throat of the carb...I have never dealt with the TORS so I can't help you, but I would highly suggest getting the TORS removed to save on many headaches now and in the future! I will definately be looking into getting the TORS removed kit. Does anyone know what might be causing the one carb slider malfunction so I can fix it for the meanwhile? Do I tear into the tors? Is there an easy fix to get it working again? Quote
Paddleboy Posted July 17, 2008 Report Posted July 17, 2008 instead of f*cking with the tors you could prolly just buy a new set off someone for dirt cheap off here. Quote
shee4speed Posted July 18, 2008 Report Posted July 18, 2008 Remove the carb top and see if the cable is connected to the slide. Quote
mofoka Posted July 22, 2008 Author Report Posted July 22, 2008 Remove the carb top and see if the cable is connected to the slide. Yeah, it was fine there. It ended up that in the 'Y' the one cable slipped off and wasn't pulling. I can't believe I've been running it for so long like that. I've make shifted back for now until I buy a new cable. Seriously, how was that possible...? Oh well, it is twice as good now! Quote
