hey just started to look at my bike after i installed the YFZ arms and kfx shocks and if you look at the tires the bottom sticks out a little bit like theyre on a angle almost any ideas why this would be? like i mean theyre not straight up and down the on a angle
Before work bump
idk im not good with alignment but is the camber adjustable if you cant figure it out just take it to get aligned im sure it wont cost much
Edited by banshee404
I think the yfz got a slight angle to them, about how much are you talkin about? I dont think there is any adjustment on those so they should be ok. Can you post some pics?
adjust the ball joints on the a-arms.
if you look at the pic you'll notice they're non-adjustable, i'm hoping he could have figured that out himself.
it almost looks like it's sitting like that b/c of the longer shock, do you have a different set just to try?
all you have to do is get adjustable upper A-arms but the camber helps some in cornering since tires will big sidewalls "fold" but with some camber the tire doesnt fold onto the sidewall = more front grab.... but there is such a thing as too much camber. YFZ arms normally do that anyway... what happens when you put parts on a quad that its not built for :blink: hope this helps :beer:
exactly, those arms are designed for a yfz frame, the front end geometry is obvisouly nowhere near the same on the banshee, although ive never seen a 450 front end on a banshee with that much camber in, some camber is good, helps cornering, but thats just too much, somethin aint right there
