Bill Posted May 27, 2008 Report Posted May 27, 2008 It almost looks like someone drilled A hole there for some stupid reason. I can't see the chain slapping A perfect hole there. your gonna haft to figure out some way to plug it perminently with out binding the clutch arm. Quote
BellicoseBanshee Posted May 27, 2008 Report Posted May 27, 2008 Nothing like that on my case, not even the little holes/dimples to the rear of the large hole. Doesn't look like a piece broke off, it looks like a hole was drilled, as metioned. All three look like drill holes/marks. Maybe the clutch arm was frozen in the past, and someone drilled the hole to work the arm out... :ermm: Quote
okbeast Posted May 27, 2008 Report Posted May 27, 2008 I'd pull the clutch arm and make sure it's ok. As for fixing it, not sure. Maybe try to find a dowel rod that will fit down in the clutch arm hole perfectly, then fill the hole from the outside with jb weld. If needed sand it smooth on the inside. I don't think that area takes much beating so I would think that would fix it. Quote
jonnyb Posted May 27, 2008 Author Report Posted May 27, 2008 Well there are actually only two the third is just a piece of rubber. The big one is the only one that is drilled through. I sent pics to my builder so waiting to hear back from him. Surprised he never said anything. Quote
okbeast Posted May 27, 2008 Report Posted May 27, 2008 Who's your builder, did he have the bike before you? Quote
jonnyb Posted May 27, 2008 Author Report Posted May 27, 2008 A&S Racing, waiting for him to call me back. His wife or Girl called me after I sent pics and said that it was like a breather plug and to super glue it back in lol? Told her that no body knew what it was and super glue is not going to get it done. she's going to have Dan call me. Quote
jonnyb Posted May 27, 2008 Author Report Posted May 27, 2008 Yes I just got it back less than two weeks ago. Quote
flyhighprerunner Posted May 27, 2008 Report Posted May 27, 2008 This is probably e-relavent but what year are those cases so i can look at it in an exploded view just to make sure were looking at the same things.... Quote
lonestar Posted May 27, 2008 Report Posted May 27, 2008 (edited) Looks like someone drilled a hole to remove a frozen clutch push rod & ball. (access hole) Edited May 27, 2008 by lonestar Quote
jonnyb Posted May 27, 2008 Author Report Posted May 27, 2008 I just need to know what to do with it. I'm thinking the same thing lonestar. Quote
jonnyb Posted May 27, 2008 Author Report Posted May 27, 2008 Thats what someone did last time but it poped out. Quote
Bill Posted May 27, 2008 Report Posted May 27, 2008 Well then the correct way to do it would be to weld it,but I would split the cases to do that. :shrug: Quote
jonnyb Posted May 27, 2008 Author Report Posted May 27, 2008 Do you guys think that it can be jb welded with out spliting cases? Quote
