BaNsHeEs RuLe! Posted April 25, 2008 Report Posted April 25, 2008 Klotz BeNol, 40:1, ran it in my '92 every single tank since it's first ride. No sludge on the pipes, no residue, very little smoke, the wonderful smell of BeNol, the best lubrication next to KY. My .02 Quote
pasedogg Posted April 27, 2008 Report Posted April 27, 2008 what do you guys recomedn for my oil ratio, i have a stock banshee, bored once i thhink, i got fmf fatty gold series pipes, uni air filter, TORS remved.im 300 above see leval, Quote
Profilact Posted May 7, 2008 Report Posted May 7, 2008 Wow, Im suprised. Keep in mind, I am new, but I've been running 26:1 for as long as I've had the bike. I guess from not knowing better I just figured that more oil may foul a plug, but I deffinately have enough lubrication for everything in the motor. I have never fouled a plug, and have ridden a good 6 hours at a time(not sure if thats a lot). With the leaner mixture, could I expect any noticeable difference in HP? I would surmise that more gas, less oil would explode more violently. Quote
LS1Inferno Posted May 7, 2008 Report Posted May 7, 2008 With the leaner mixture, could I expect any noticeable difference in HP? I would surmise that more gas, less oil would explode more violently. Yes and no you could gain HP, but the more lube the less friction, its just up to you, with that ratio if its fine leave it, the motor should last quite a while if its fine, you could drop change the ration and see if you gain more power. Quote
