Found out my machienist isn't a wiseco fan (pro-x). other than warming it up, does everybody just go by the clearaces wiseco says or have you guys (w/ experience in strictly drag motors) found something better to go w/ on clearances. Does no2, alky ect...make a difference either?
Dave
all types of riding should be pretty much the same. the metal will expand to the same amount once it hits the temps. so riding drag or mx as long as the temps are met the metal "should" expand the same amount. So the clearances should be the same. better person to ask would be either Firehead or BellicosBanshee ( I'm sure i spelled his name wrong), the both of them are Mechanical Engineers and have a better understanding of it from more then just opinions
i had more problems with pro x pistons than any of the wiseco's ive ever had the clearances are there for a reason set them to spec and run them.. my pistons with heavy drag racing usually last about 2 years at least,
