Thanks a lot man. I was looking for something different and I didn't want to go with silver as a quad already had WAY too much silver on it to start with. Really generic color to me.
So I thought gray would look good then I found this gray metal flake stuff and thought it would be even better. I'm happy with how they turned out. Just hope the paint holds up ok. If not easy enough to spray em every couple of months though.
i thinbk it looks really good did you use high temp paint? I heard if you use grill paint it works the best.
Didn't use hi temp, just got the pipes hot and then sprayed it. Bakes the paint on that way and it will stick.
what was the brand name of the paint it looks really fresh. my t5 need a fresh coat and it sounded pretty easy.
It was dupli-color metallic gray. Found it at walmart. Hate buying cheap walmart crap but this was good stuff. About 5 bucks a can. I can snap a pic of the can this weekend.
nice job. i did the same to my sled pipes. only i just let them sit on a wood stove for 30min. paint them with tremclade bbq paint a good 3 coats. then put them back to dry and recook. then i gave 2 good coats of gloss black and put them back on the stove.. works great
sup man, i did my silencers with a black nickle coating ill post up the pics so u guys can check them out they look pretty sweet but expensive ass hell :/
  • 3 weeks later...
Sorry I didn't respond sooner guys. I've got quite a few rides on the machine and the pipes still look great. The only discoloration is right where the pipe comes out of the head, and almost any finish will have some discoloration there because of the heat, even chrome.
As far as covering up the rest of the bike I didn't worry about that. Just keep a wet rag handy and wipe off any overspray. It wasn't really that bad as I kept the spray to a localized area on the pipes and just painted them slowly. I got it on there without getting any on my plastics, etc.
I did touch up my frame where the paint had been rubbed off, and painted my a arms with the same paint and it looks really good.
Hey greg, are those the toomeys I sold you, if so they look really good. Take it easy Mike.
I think they look killer. Yours too Jonnyb. I would imagine that the paint you used wont hold up anywhere near as long as Hi Temp paint. I would worry about getting them wet while theyre really hot.
