I just want to know what timing, jets, and anything else that might help I just ordered a stage IV Trinity single carb intake with a 34mm kehin carb hopeing it will come jetted like it is supposed to or pretty close.
Im around the Indy area running basically the same mods - the cool head, mine rips with the oko carbs with 158 mains & 45-50 pilots with airbox lid removed, I think you may be a little lean with the pods and go to plus 4 timing with b8es plugs. Where abouts are you in Indiana? If you decide to sell 2 into 1 setup pm me. Good Luck
  • Replies 51
  • Created
  • Last Reply
Top Posters In This Topic
ok I am sending my cylinders off monday either fast or flowtec havn't decided yet but getting aggressive trail/MX porting but I still need pipes dont think fattys are going to be good for me I always liked toomeys but are they going to run a 4 mil I will get one before the end of summer and plan on a small block of some type (cheetah exc.) next winter I dont want to buy new pipes and have to upgrade again in less than a year or can you put toomeys on a cheetah cub and what about LRD, DMC, vitos and all the other ones there are so many I dont know what ones are good
Edited by yam_fan
Just spent alot of money a lot of new parts and not much results to start with I bought a banshee than ran like crap so replaced almost everything starting with, new stock cylinders 64mm, vitos ported pistons, new high output stator, new 5 degree advanced timing rev box, kill switch and wirring, new coil pack, new prodesign coolhead, stator plate, and impeller, new ebc dirt digger clutch, boss intake, 30mm oko carbs, k&n pods with outer wears, new V-Force 2 reeds, and some other things I am currently running at minus 1 degree timing(because of rev box)so it should be plus 4, 17cc domes, 112 octane race fuel, br9es plugs, toomey t3 pipes(I think) and it isn't fast at all I have had 6 banshee's almost alawys had them built at local shops. I did this one on my own and I am very let down I need tips on what everything should be set at for a good mid and fast top end. it feels like it has no power band at all bottom end that isn't that great either.
Did you replace all these parts trying to fix a running issue or just adding parts on? Why doesn't the bike run good, what does it do?
