  • Replies 51
  • Created
  • Last Reply
Top Posters In This Topic
Whats your altitude? You sound like it might be RICH. The pilot jet is under the carb bowl next to the main jet and should be tight, the 1 1/2 turns out relates to the Air Screw located on the out side of the carb.
ok I dont know what pilot I only checked my air screw thought that was the pilot up until now, I am as dumb as you get when it comes to carbs never have been able to adjust them
Drop to a 155 main do a plug chop. Is your lid on the airbox? what are you mixing your fuel at?
30mm carbs, dual pod filters, and since they are new cylinders I am running 32 to 1 and 112 octane for the 17cc domes
you dont really need to be running a 17cc dome, you could go bigger and back off the octane. although that wouldnt fix the issue your having with how its running
I already planned on it just got my 20cc domes in the mail
You said you have T3's on it? you need new pipes and to rejet them carbs. I run the same mods as you at sea level with a port and jetted right, This Bitch Hauls the Mail for sure! You should be kicking some ass. Call CPW Carb Parts Warehouse do a search on here their # is posted or contact Wacko 2000 s/p? he called them the other day, he might still have the #. They will set you up right, tell them your mods and he will fix you up. :thumbsup:
also put that electrical timing POS back for sale on ebay and adjust the advancement from the stator plate.
I regret buying that cdi but at the time it sounded good I didnt have my stator plate until right after that
any ideas what I should set my timing
I run everything you do even the gas and mix I am at +5* and 160 Main and 50 pilot jet. at sea level so you should run a 48-50 pilot, and a 155-160 main. Jets are like $2.50 a pop so they are cheap, call cpw and buy the right jets. Put you timing at +5 and GET NEW PIPES!!!
I will try that I might just throw the stock cdi back on too
Yep I would do that, also rund Br8es plugs not the 9's wrong all round.
what kind of pipes should I be looking for I plan on 4mil crank then cheetah cylinders this summer
