You should change your wrist pins everytime you overhaul the top end. Reguardless if they look okay, the new ones are also the same size as your stock connecting rods. Hope this helps.
I would replace both, pin and bearing each fresh top end. Do you have to? Nope...but to be 100% honest, it's cheap insurance...and you're gonna have it apart any way, so...not like it's extra labor.
wrist pins in a 2 stroke wear very quick compared to the rest of the bearings. if i had to guess i would say it is because of the additional heat that the wrist pin sees being so close to the piston crown. its literally right underneath it. brand new wiseco wrist pin bearings only run $10 each. if you going to replace some top end parts. you might as well do the job right and replace the wrist pin bearings at the same time.
what is that old saying. if something is worth doing, its worth doing right!
smaller bearing for the same amount of load and less lubricated also.
Wiseco pistons come with new pins and clips but no berrings. I believe majic racing throws in the berrings when you get one of there kits.
Correctamundo...
Magic has a pretty good price on a complete top end kit, bearings, seals....etc.
