Cory9584 Posted January 6, 2008 Report Posted January 6, 2008 i have alot of heavy carbon buildup inside my pipes, is there any easy way to clean it off? It wont even scrape off easy. Quote
chillls Posted January 7, 2008 Report Posted January 7, 2008 not to be a smart ass but good luck Quote
fastrthnu Posted January 7, 2008 Report Posted January 7, 2008 try to find a wire brush with a long stem and stick it in the end of a screw gun after swishing around some paint thinner or something in there. then fill it with gunk engine brite foam to soak for 10 min or so then wash it out with a hose and let it dry out. Quote
Cory9584 Posted January 7, 2008 Author Report Posted January 7, 2008 Is it normal to have buildup or is it from the poor state of tune the bike was in when i got it? Quote
fastrthnu Posted January 7, 2008 Report Posted January 7, 2008 Is it normal to have buildup or is it from the poor state of tune the bike was in when i got it? eventually no matter what it will build up from unspent emissions. A motor running very rich will accumulate that build up much quicker though. Quote
350BANSHEE350 Posted January 7, 2008 Report Posted January 7, 2008 im pretty sure there is a method for it and there are a couple vids on youtube .. not sure what they use but it has to do with fire and heat Quote
Frogger Posted January 7, 2008 Report Posted January 7, 2008 Should you clean the insides of them every so often? Quote
BigRed350x Posted January 7, 2008 Report Posted January 7, 2008 eventually no matter what it will build up from unspent emissions. A motor running very rich will accumulate that build up much quicker though. Depends a LOT on the fuel you run, and the type of oil you use. A lot of oils will produce more carbon buildup than others. I can see very very little carbon buildup if any after over a year of use with my shearers and running on methanol with castor927. I've heard that klotz super has even less carbon buildup. Quote
jbooker82 Posted January 7, 2008 Report Posted January 7, 2008 Look and see if you can find a boiler wire brush. It should look like a bottle brush that you use to do the dishes. They come in various lenghts. Quote
