Outlaw MX Banshee/ 250r GEometry for sale $5200
The complete bike is $5200
Chassis is $3500 with shocks $2700 with out
The motor is not running right now so if nobody wants it it will be parted out and the chassis will be sold motorless. All prices are firm, I'm letting this go cheap and for any less, it's going to leave in parts on Ebay.
Shaffer Chromoly LT chassis, swing arm and +3 A-arms, adjustable wheelbase.
Elka quad rates, SSD front and rear
Passion built 12 port 4mil RZ motor
The motor has RZ jugs and head(cut for 110)
Banshee cases
RZ shift forks and drum
Banshee clusters
Fast Racing clutch with pancake bearing(Basket, fibers, steels, pressure plate, inner hub all have about ten hours on them)
Prodesign billet intakes
Lectron 32mm carbs
Rocket pipes
Quick change clutch cover
Durablue axle
Hubs to convert Honda spline to Banshee bolt pattern(expensive durablue part)
Durablue Sprocket and brake hubs
Shaffer Chromo stem with LS antivibe clamp
-400ex spindles, rotors, hubs, calipers
-no link swingarm 250r
-ac pro pegs
-+ 4'' durablue axle 250r
-250r rear caliper
-250r antifade locknut
-custom alumnium airbox w/ yz filter
-lightened flywheel
The bike is awesome, it's hard to describe unless you have ever ridden one.
The motor makes hp around low 70s when tuned right, but has an insanely broad powerband from the Powervalves.
How much for the complete clutch setup? I keep forgeting you are trying to sell this. There is a couple other parts I might be interested in too
$200
The entire set up has around 10-15 hours on it, all trails.
Magnum basket with gear
FAST fibers/steels/springs
inner hub, pressure plate
pancake bearing
It has RZ shift forks and drum in it if you're interested in that as well.
  • 1 month later...
  • 2 months later...
wanna trade for a yfz450 for your hole quad maybe a 94 pontiac sunbird with 84000 miles on it run and look good , maybe a 6x 16 trailer? let me know?
  • 3 months later...
Sorry man. That bike has been parted out and sold. I bought the chassis off of broke. I think someone else bought the motor from him.
yea I have it and the pipes :biggrin:
