How do I tell what size my carbs are i know they are PWKS.They were on the bike when I bought it along with the other mods I have in my Sig.I dont think I went wrong for 1K I have had a few issues but with the help from BHQ members and the wealth of info on this board My bike will now stretch my arms out and make me giggle like a little kid well headed to the dunes HAPPY NEW YEAR to everybody.
Jeff :thanks:
You mic the bell of the carb to find out what size it is but there should be numbers on the side of the carbs. Put those numbers up and I will tell you what size it is. It should say 70A For example.
The numbers on the side are as follows 73RABML
Thank you
Jeff
Thank you
Jeff
I cant find it these are what I go by. I see 72R and thats a PWK 39, PWK41 Pro-Series doesnt have a number. Looks like its time for the carb nuts to get in on this or Im sure Jim from Passions Racing would know.
Description Mark* Standard PWK No. Special Set No. Diagram & Parts List
PWK28 29S" 016-144 016-189 Diagram & Parts
PWK33 S46" 016-148 016-191 Diagram & Parts
PWK35 70R" 016-150 016-192
PWK35 A/S S65" 016-160 016-197 Diagram
PWK36 S63" 016-163 016-198 Diagram & Parts
PWK38 71R" 016-153 016-194
PWK38 A/S S66" 016-167 016-199 Diagram
PWK39 72R" 016-155 016-195 Diagram & Parts
PWK41 Pro-Series -
http://www.sudco.com/pwk.html
They are probably PWK 28's
Look at the keihin diagram on sudco's web page shows 73R PWK 28mm
Sudco PWK LINK
Do the carb caps screw on and off or do you have to remove 2 screws and the top plate comes off?
Maybe the 73R PWK 28's have the style of carb cap like all the other PWK's where it screws off.
The 29s PWK 28mm may have the 2 screws to remove and then the top plate comes off
josh
if you really wanna know,
just measure the diameter of the thru bore of the carb (carb throat).
if you are measuring in inches multiply the measurement by 25.4.
that will be the carb size.
(if ithe diameter measures 1.14 it is a 29mm carb.)
Edited by brian
shit,
bring em into OKC and i'll measure them for you if you
don't have the tools.
Edited by brian
Sudco PWK LINK
josh
I do not have the large plastic cap on the top they have 2 screws to get the top off when I have to tear something apart I will put my calipers on it and see what size they are If 28mm should I upgrade or stay the same.
Thanx
Jeff
upgrade when you are gonna get the cylinders ported.
then you will need better fuel delivery.
Thanx
Jeff
Yea you have keihin pwk 28mm's. If I had a piped banshee I would probaby run those carbs, just to get rid of the stock ones.
Many Thanx for the info These carbs are on the bike the previous owner told me they did a fresh rebuild on the top and bottom end but I can not prove that.The bike runs awsome Just got back from Little Sahara Ok.To tell the truth I was going to buy a Chinese Clone 250 but I found the Banshee just before going to pick up the 250 and got it cheaper a choice I am very happy with.
A VERY BIG THANK YOU TO EVERYONE THAT HAS HELPED ME
HAPPY NEW YEAR
Jeff :beer:
