BIGSHO Posted December 26, 2007 Report Posted December 26, 2007 my throttle stuck wide open the other day out riding. i checked the cable and all is fine. i took the cap off the top of the carb and inside there, where the cable goes in to the carb there is no tension on the cable. when i pull on the throttle cable it does not pull back into the carb by itself. if i push the thumb throttle the cable pulls back in, but it wont do it by itself. the other side is fine. is there a spring inside the carb itself that should return the throttle to idle. do i need a whole new carb? thanks....bigsho Quote
wesw Posted December 26, 2007 Report Posted December 26, 2007 there should be a spring that pushs the slide down. if the other owner removed them he deserves to be shot. inside the slide the cable goes thru it. Quote
BIGSHO Posted December 26, 2007 Author Report Posted December 26, 2007 are you talking about the big spring underneath the cap on the carb? Quote
BIGSHO Posted December 26, 2007 Author Report Posted December 26, 2007 no that spring is fine. is there something inside the carb that should make the throttle cable return to its normal position? Quote
BIGSHO Posted December 27, 2007 Author Report Posted December 27, 2007 is there anything under the slide that should pull the cable back down? also is it normal for there to be dirt or moisture in there? Quote
wesw Posted December 27, 2007 Report Posted December 27, 2007 it goes slide, plastic clip cable latch, spring, then cab if your slides are not shutting down all the way its either the springs have been cut or not strong enough or the cable is sticking. Quote
BIGSHO Posted December 27, 2007 Author Report Posted December 27, 2007 it is just one side whatever the problem is, it is below the slide. how do i remove the slide to chech below that? do i just pull it up? also should it have dir on the slide? Quote
tedd1 Posted December 28, 2007 Report Posted December 28, 2007 If you got dirt and/or water in the carb, you need to check your air filter(s). You are sucking dirt around them somewhere. Quote
BIGSHO Posted December 28, 2007 Author Report Posted December 28, 2007 the dirt is in the top pat of the carb underneath the cap that the throttle goes through. i beleive on top of the slide. Quote
tedd1 Posted December 29, 2007 Report Posted December 29, 2007 Pull the tops off the carbs and check. Unscrew the cap and pull everything straight up and out of the carb body. If there is dirt on top of the slide, you may have to clean it out with carb cleaner before the slide will move freely. There should be an O ring on top of the body under the cap. There should also be a rubber grommet around the cable where it goes into the cap. If you have dirt anywhere in the carb, find out how it is getting in there and fix it! Quote
mavguy Posted December 31, 2007 Report Posted December 31, 2007 While on the topic...Are there many ways to make the throttle on a Banshee lighter? I've heard of people switching the thumb mechanism with one off of a 400ex or something with a bigger thumb lever. Is it possible, or a good idea, to trim the carb springs? I find my throttle to be fine, unless i am riding a long time at 3/4ish throttle, like down a road or something. Thats normally when it becomes a bit sore, especially in the cold. Quote
BIGSHO Posted December 31, 2007 Author Report Posted December 31, 2007 (edited) the cable moves freely. when i push the thumb throttle the cable pulls in through the top of the carb. when i let go of the throttle the cable stays down. i can just pull the cable back out with my hand but it doesn't return by itself. is something stuck inside the carb? Edited December 31, 2007 by BIGSHO Quote
375hp banshees Posted December 31, 2007 Report Posted December 31, 2007 does it return (spring back down) when the slide assy. is out of the carb. (w/ caps unthreaded & the whole assy just hanging) usually the moisture /dirt is all that it is...clean the slides & bores good if they work ok outa the bores....find & seal the contamination inlet source! Quote
BIGSHO Posted December 31, 2007 Author Report Posted December 31, 2007 the cap is where the dirt was getting in, where the cable goes throught the cap had duct tape on it. i just got the bike not too long ago and never fixed that. but no with the slide and all out it still doesn't return. the only way the cable moves is to push the throttle or pull the cable back out by hand. Quote
