sa3ood_banshee Posted December 14, 2007 Report Posted December 14, 2007 k i no this is asked alot but i need help(i searched),so i have decided to get haulers,so how many paddels should i get ,my shee is bone stock,and do u guyz think i should get rear wheel spacers,what r they gd for,i only ride in tha desert sa3ood Quote
badassbanshee479 Posted December 14, 2007 Report Posted December 14, 2007 22-11-8 8 paddles if you drag race at all, or a set of 20-10-10's 8paddles if you just like to screw around and have fun. I would not run wheel spacers, to much stress on the wheel studs. if you wanna make your bike wider, buy an axle and a set of 2+1 arms Quote
sa3ood_banshee Posted December 14, 2007 Author Report Posted December 14, 2007 thnx for tha info dude,and wont a setup of a size 9 rim be good,cuz thatss tha rim i have sa3ood Quote
BellicoseBanshee Posted December 14, 2007 Report Posted December 14, 2007 thnx for tha info dude,and wont a setup of a size 9 rim be good,cuz thatss tha rim i have sa3ood If I recall, Haulers will only fit 8 inch or 10 inch wheels... 21X12X8 eight paddle Haulers work well and I would stay away from wheel spacers if I were you... Quote
sa3ood_banshee Posted December 14, 2007 Author Report Posted December 14, 2007 alright guyz i think ill go for size 10,and thx for tha tip on spacers sa3ood Quote
sa3ood_banshee Posted December 14, 2007 Author Report Posted December 14, 2007 so what du u think 6 paddles or 8?? im running a bone stock shee Quote
bk_banshee Posted December 14, 2007 Report Posted December 14, 2007 so what du u think 6 paddles or 8?? im running a bone stock shee So first off I see you from UAE. greeting from a far. for your type of sand and riding conditions that I have seen down there you will want a set of 22X11X8 8 paddle haulers in a medium buff compound on a set of douglas 8X8 Blue label rims This is mostly for the hill and flatdrags that I have seen if you actually run the desert link an enduro or baja then black label wheels but I wouldn't run paddles. You will need to get new sprockets to lower your gear ratio with the larger tire. 10 in rim is the wrong way to go. keeps your tire too square causing you to have more paddle slap on the top end. same problem with a 20X10X10 tire. You want the tire to round so at higher speeds only portion of the paddle is hitting the sand. Quote
sa3ood_banshee Posted December 14, 2007 Author Report Posted December 14, 2007 k thx for tha info 2,but now im confused,btw were in uae have u been,and next time u cum 2 tha uae we can go ridding shee'z sa3ood Quote
bk_banshee Posted December 14, 2007 Report Posted December 14, 2007 k thx for tha info 2,but now im confused,btw were in uae have u been,and next time u cum 2 tha uae we can go ridding shee'zsa3ood Tell me what your confused about and I'll help out Never been to the UAE. Seen lots of pics and worked at a shop where we had a couple of customers down there. Have done lots of reading about it as I want to go there for a vacation some day. Quote
sa3ood_banshee Posted December 14, 2007 Author Report Posted December 14, 2007 (edited) Tell me what your confused about and I'll help out Never been to the UAE. Seen lots of pics and worked at a shop where we had a couple of customers down there. Have done lots of reading about it as I want to go there for a vacation some day. k now what should the tire size be and how manny paddles,im not gonna dragrace,just screwing around and playing in sand,but i want a gd setup without changing tha stock gearing,btw ur alwayz welcum at my pl ace man edit; lsn man im gonna go to sleep now ill reply ya tommorow,its freaking 3:00 am here sa3ood Edited December 14, 2007 by sa3ood_banshee Quote
Michael Jackson Posted December 14, 2007 Report Posted December 14, 2007 22-11-8 8 paddles if you drag race at all, or a set of 20-10-10's 8paddles if you just like to screw around and have fun. Quote
bk_banshee Posted December 14, 2007 Report Posted December 14, 2007 a set of 20-10-10's 8paddles if you just like to screw around and have fun. I disagree completly. It's my opinion but there is nothing good about this tire from a sand perspective. a new 44tooth rear sprocket. and a set of 22's all you need to do is put some slack in the chain and roll off the chain undo 6 nuts, slide the sproket off over the wheel hub then reverse these steps with the new 44 tooth sprocket. Quote
jbooker82 Posted December 15, 2007 Report Posted December 15, 2007 I would get the 20x10x10 8 paddles too. The shorter tire will be better for just messing around. 22's will be to tall and they will want to roll instead of slide, and they will kill power. Quote
