  • Replies 55
  • Created
  • Last Reply
Top Posters In This Topic
a properly jetted carb you should have to use the choke to start it when cold. can you start yours without using the choke at all?
Sorry if i was unclear. I do need the choke to start the bike but when Its running and i pull the choke out it dies almost straight away. I was writing that in response to blessedwithdeath's question.
ok then your pilot is fine. i thought you where saying that you couldnt use your choke at all.. my bad
Ive been researching this topic non stop. I havent really found any solution but I think I will go up in the main and do a plug chop that way. Then I can be sure Im not running lean and cause any real damage. Then Il take it from there. Jetting sucks ass!!!! :down: lol
there has to be something besides your jetting, either a clogged carbs or a leak or something.
What makes you think it could not just be jetting banshee man? Ive cleaned the carbs twice and am confident there is not dirt in them. Where would the leak be? How would I know what to look out for?
got a spary bottle with some soap and water and start hitting all the surface areas with the motor running. look for bubbles.
it just dont think its your jetting becasue your running the same jetting as 95% of the guys with the same setup and have no issues. and Mark ran that same motor with zero problems. did you ever get a chance to do a leak down?
No never got a chance but i think Il do one tonight or tomorrow morning. Should I still go up in the main do you think? Or just do the leak test and take it from there?
What's your size on the pilot jet????? Just curious, i'm having bogging issues as well.
Its standard. Im pretty sure they are 25 standard. then the go up in 2.5's so the next one is 27.5! Some one will correct me if Im wrong. :blink:
i would look to see if your boots are cracked where the boost bottle connects. i seen this more then once. it was the side closer to the cylinders. even if you spray the area with starting fluid wile the shee is running. if it idels high after you spray they are or 1 of them is cracked and your are sucking air causing it ti run lean. you can also use a propane torch (UNLIT) just turned on running it over your engine to look for a change in idle.
Ok, looks like you've tried everything on the jetting, now an od question, Are your reed petals sealing? Do you have stock reed valves? If you have stock reeds, do you use the metal reed stoppers on them? Maybe one of the reed plates have come loose? Check you reed valves.
I think they are sealing. I did the leak down like banshee man said below and didnt see any bubbles but I mite try another like blessedwithdeath saidto be on the sure side. Although I dont have a boost bottle blessedwithdeath cos i didnt think i cud handle the hp them babies add!!! :yelrotflmao: :yelrotflmao:
Ive stock reeds wikth the metal reed stoppers. Il check and double check all the reed set up 2strokespirit. Thanks.
O do I need to take them off to check them? Or is that a stupid question?? :geek:
I love the way the help on this site just keeps coming. :clap: :beer:
