having problems with my 87 banshee took out the carbs that had the TOR's still on them and put new carbs from an 02 banshee that had a TOR eliminator kit on, since the change only one cylinder is running. i checked for spark, gas its all there but still only runs off one cylinder anyone help with this???? :confused:
did you reconnect the choke tube between the 2 carbs? Easy miss, easy fix, will give you problems for hours until you find it sitting between the lugs of your tire
hey everyone thanks for the help. come to find out i should have left it stock since it was running on one fried piston :down: , did a quick compression test had nice 150psi on one and a whole lot of nothing on the other. this give me an excuse to just build it lol. my only advise to everyone else dont spend alot of money on parts tell you do a compression test!! :cool:
