Pictures Of Float Bowls
flattrakker
On another note.. I dont have any pics but I can kinda explain it a lil bit. After you remove the float bowl the first thing you'll see is a white splash guard that surrounds the Main jet. The Main jets is a brass hexagon and is a 6mm head (I might be wrong on the size) After you remove the main jet and splash shield you notice a hole right next to the main jet. The splash guard had a section that seated in that hole. This is where the pilot jet is located. You'll need a small straight screw driver to remove it. the other stuff you see is going to be the needle and seat assembly. Thats the quick version of it. You'll have to get a service manual for a more detailed version.. Or maybe someone else will chime in with some pics.
