flattrakker Posted November 17, 2007 Report Posted November 17, 2007 Can someone come up with some pictures of inside the bowl so when i rejet i know what im looking at.. that would be awesome if you could label it in the picture too. i would like to know where the airscrew, mains, needle clip, and pilots are. Thanks in advance! Quote
biggun6ss Posted November 17, 2007 Report Posted November 17, 2007 I would say get a Clymers, it will have all the pictures you need. You could also look up the stock carb on the internet and get some nice views. Quote
BellicoseBanshee Posted November 17, 2007 Report Posted November 17, 2007 (edited) I am not trying to be rude, but you really should buy a Clymer manual...$30.00... Yamaha Banshee, 1987-2006 EDIT: Beat me to it... :thumbsup: Edited November 17, 2007 by BellicoseBanshee Quote
shanYE west Posted November 17, 2007 Report Posted November 17, 2007 I bought a service manual CD from ebay. for like 7.00. Its identical to the ones we use at the dealer. Quote
shanYE west Posted November 17, 2007 Report Posted November 17, 2007 On another note.. I dont have any pics but I can kinda explain it a lil bit. After you remove the float bowl the first thing you'll see is a white splash guard that surrounds the Main jet. The Main jets is a brass hexagon and is a 6mm head (I might be wrong on the size) After you remove the main jet and splash shield you notice a hole right next to the main jet. The splash guard had a section that seated in that hole. This is where the pilot jet is located. You'll need a small straight screw driver to remove it. the other stuff you see is going to be the needle and seat assembly. Thats the quick version of it. You'll have to get a service manual for a more detailed version.. Or maybe someone else will chime in with some pics. Quote
richybanshee Posted November 17, 2007 Report Posted November 17, 2007 Buying the manual is a good idea but for the moment you can manage without it. Check this article on jetting. It has the pics you need and alot more. Hope this helps!!!! :biggrin: http://www.dfn.com/benkaren/jetfaq.html Quote
shanYE west Posted November 17, 2007 Report Posted November 17, 2007 Buying the manual is a good idea but for the moment you can manage without it.Check this article on jetting. It has the pics you need and alot more. Hope this helps!!!! :biggrin: http://www.dfn.com/benkaren/jetfaq.html Nice! :thumbsup: Quote
flattrakker Posted November 17, 2007 Author Report Posted November 17, 2007 i found that shortly after i posted.. thanks Quote
samc Posted November 18, 2007 Report Posted November 18, 2007 http://www.sandwizards.com/Service_Manuals/Banshee.pdf enjoy. Quote
richybanshee Posted November 19, 2007 Report Posted November 19, 2007 http://www.sandwizards.com/Service_Manuals/Banshee.pdf enjoy. Thanks :biggrin: Quote
