951zach Posted November 5, 2007 Report Posted November 5, 2007 My wifes blaster is running like crap.Went to glamis and cant get any power out of 4th,5th,or,6th gear.Removed TORS already helped some but still no top end idles well. has a 270 main jet and a 35pilot,pro circut pipes ,k&n filter,besides that stock.Can anyone help with this im not sure what to check,bike starts fine. Quote
mall0y Posted November 7, 2007 Report Posted November 7, 2007 My wifes blaster is running like crap.Went to glamis and cant get any power out of 4th,5th,or,6th gear.Removed TORS already helped some but still no top end idles well. has a 270 main jet and a 35pilot,pro circut pipes ,k&n filter,besides that stock.Can anyone help with this im not sure what to check,bike starts fine. When was the last time you rebuilt it? What kind of compression does it have? Also, what does the plug look like? Quote
951zach Posted November 8, 2007 Author Report Posted November 8, 2007 When was the last time you rebuilt it? What kind of compression does it have? Also, what does the plug look like? I got it last march and the guy said it had a fresh top end ,unsure about compression,as for the plug its dark at the top but not black. I was running 24:1 but found it to be to rich and just recently switched to 32:1. I Quote
DuneRookie Posted November 14, 2007 Report Posted November 14, 2007 I have had 3 blasters. sounds like you are either way to rich or its your top end. I ran 32:1 and always use 91 octane. I was jetted anywhere from about a 260 -290 main....open air box wK&N filters and preskins. Quote
951zach Posted November 18, 2007 Author Report Posted November 18, 2007 I have had 3 blasters. sounds like you are either way to rich or its your top end. I ran 32:1 and always use 91 octane. I was jetted anywhere from about a 260 -290 main....open air box wK&N filters and preskins. thanks for the advice. I think you might be right.i changed the plug even though it looked fine.and pulled out the reeds and noticed that one side had a small gap and so i fliped it around and now thers no gap Hope fully its better, still havent ridin it.Do you think this would cause me to lose power.the bike feels like the choke is on. Quote
shee4speed Posted November 18, 2007 Report Posted November 18, 2007 A friend of mine had that problem and turned out to be piston too small. Quote
LS1Inferno Posted November 19, 2007 Report Posted November 19, 2007 thanks for the advice.I think you might be right.i changed the plug even though it looked fine.and pulled out the reeds and noticed that one side had a small gap and so i fliped it around and now thers no gap Hope fully its better, still havent ridin it.Do you think this would cause me to lose power.the bike feels like the choke is on. Theres supposed to be a slight gap. I dont have the manual on hand, but are they stock reeds? Quote
inthemail Posted November 19, 2007 Report Posted November 19, 2007 (edited) first thing that came to mind was going down a bit on your jetting. pick up a few between 220 up to your 280 and youll be good. (for a while id imagine, spares are good to have) running 32-1 high test with a good oil is always recommended. my reeds never have gaps they always close fully and almost stick shut a bit when you open em with your finger gently, however a cracked bent chipped or otherwise shitty reed probley could cause a choke on feel Edited November 19, 2007 by inthemail Quote
