sheerider1026 Posted October 28, 2007 Report Posted October 28, 2007 am on my way to buying a frame ( no doubt) but the frame i have, the dam retainer nut on the steering stem bearing will not budge.. there is nothing we have not tried.. was wanting to maybe get this frame fixed to keep as a spare and maybe pc later.. any ideas on the retainer nut?? any of u guys ran into this before? Quote
Bansh-eman Posted October 28, 2007 Report Posted October 28, 2007 are you talking about the nut on the bottom of the stem or the one thats inside the frame? Quote
sheerider1026 Posted October 28, 2007 Author Report Posted October 28, 2007 the one inside the frame.. and yes kroil oil (orange can) i use that .. it is in there bad.. i broke a strongarm, impact wont touch it.. the frame is kinda beat up so im going to just get another frame i guess.. its a shame.. Quote
kojack Posted October 29, 2007 Report Posted October 29, 2007 the one inside the frame.. and yes kroil oil (orange can) i use that .. it is in there bad.. i broke a strongarm, impact wont touch it.. the frame is kinda beat up so im going to just get another frame i guess.. its a shame.. what are you dropping in there to remove the nut? I had a problem removing mine to and I went to the hardware store and bought a huge nut that dropped in the hole that I could put a socket on top of it as well to get it out. The nut i bought was 28.5mm by 16.5mm but I would encourage a 30mm nut. This one was a little to small. If I can next time I want one about an inch tall so i can get a better grip on it with my socket. Good luck Quote
sheerider1026 Posted October 29, 2007 Author Report Posted October 29, 2007 yes i went to fastenal and bought a 30mm hex nut.. that fkin thing is in there.. time for a nice powdercoated frame i guess. Quote
jbooker82 Posted October 29, 2007 Report Posted October 29, 2007 Heat it up with a toarch. Then take a birthday cake candle and run around the out side. That way the wax melts and gets drawn in to the threads. Quote
FireHead Posted October 29, 2007 Report Posted October 29, 2007 the one inside the frame.. and yes kroil oil (orange can) i use that .. it is in there bad.. i broke a strongarm, impact wont touch it.. the frame is kinda beat up so im going to just get another frame i guess.. its a shame.. Heat + Impact gun. I have come across a few frames that seem to have had some sort of turbo loctite on the threads in there. Heat was the only thing that got the nuts moving. Quote
Snopczynski Posted October 29, 2007 Report Posted October 29, 2007 let it soak in penetrating oil overnight, then heat it, try to tighten it a little bit, then try to loosen it. Quote
sheerider1026 Posted October 30, 2007 Author Report Posted October 30, 2007 nothing. soaked for a day, heated red. use impact and strongarm.. its fukd. i need a better frame anyway. not gonna sweat it.. gonna get my dremel out and grind it out.. if i screw up the frame to hell with it.. lol Quote
theshee Posted October 30, 2007 Report Posted October 30, 2007 I made a tool to get it loose. I got a big nut that fit it, welded it to a 1" piece of pipe, then put it in there, grabbed the pipe with a pipe wrench and it came loose no problem. I was in the same boat as you, it wouldnt budge any other way. Quote
