I just want a general idea on what jetting you guys are running out here.
I'm grabbing a handfull of jets & plugs and working my way down till I hit the spot.
My setup: Trail Port, VF3's, K&N Pods, +4 Timing, 12oz Lightened Flywheel, Shaved Head .030.
:thanks:
I run a 50 poilet in my 421 cub with a 172 main jet. I am at sea level.
On my 06 I run a 50 poilet with a 168 main jet. Still need to do some fine tuning thow.
Both run CEl nedels on midel clip. Mod in sig
2003 se standard bore, play port, K&N pods, cool head, stock carbs, t-6's
320 mains
27.5 pilots
1.75 turns out
Tuned for glamis
climb,
what does your plug chop look like before the porting? if your a little rich chances are your new port will fall right into where it needs to be.. you "shouldnt" need to go that big for a trail port.
