well as some my know i did a plug chop rescently and well the one side had a nice 2 mm brown ring the other side had a 5-6mm grey ring and a black strip through it
what does the grey and and black strip mean?
METAL!
it has freakin 25 hours on it and its an 07 and i am already having piston problems!
you joking right?
ill need to buy a new gasket if i pull the head right?
it runs excellent and it has overheated on me once but that was after the plug chop
i did the plug chop about 18 hours in on the machine after it overheated
though when i was flushing th rad i found lots of black flakes in the rad fluid
do you think it may be my head gasket that blew? it dosnt drink any coolant and theres no extra smoke and the coolant dosnt smell like gas
im really shocked that something has gone wrong already
How much did it overheat?
Sometimes you can still use the head gasket after you take it off, as long as you havn't cooked it or anything. If you don't want to take off the head just yet, do a compression test..might tell you something. If you are still uneasy about it, then yes take the head off and check. Take pictures too.
you have some sort of a problem in the cylinder with the gray plug. you may have an air-leak some where. you should definetly be doin some inspection. especially since your plug isn't any shade of brown...
and a head gasket is like $5-$10
oops up top i ment to say i did it before the overheat and 18 hours on the quad
that sucks cuz i just changed the coolant and i use engine ice so now i have to go and spend another 30 on engine ice
where could i buy just the head gasget and have it here in cananda fast?
when it overheated it the rad started to smoke it didnt have a problem running it was just smoking
the grey part does have a hint of brown and theres also a black line across it also
well thanks guys
i was hoping to have a good vacation but if i cant get a gasget in 7 days then i wont be taking my shee for the 10 day holidy
damnit
my dad sayis a light brown not greyso i dont know
you can type a thousand words about it but we need PICTURES!
and you can remove the gas tank and look down the plug holes if you dont want to remove the head.
you joking right?
Dude, no offense, but your into the wrong sport if you don't want to spend $50 and pull a head to see what's going on in your cylinders. You obviously have a problem if the two plugs are drastically different, no matter what anyone else says. Your gonna be in for a big surprise when you have an evern more serious problem because the dealer is gonna want a ton of cash to fix the bike, or your going to be looking at doing a good amount of work, more so then pulling a head.
My advice, post some pictures of the plug, we can tell you where to go from there, but I would think your looking at either a carb problem(one might be leaner then the other), or else you have an air leak somewhere. Either way I think your in for some work, which won't be all that hard for anyone with moderate mechanical experience. It will also save you a ton of cash, and time in the future if you do it right now.
its just i have had it new for 25 hours and havnt had an actual good ride without having to worry about something
we had to change the coolant like 4 times already because of other failures and since my dad works nights driving and days sleeping so i dont get any time to do anything so you know its just i was hearing all this good stuff about this quad and now i have to do all this to keep it working
well can anyone tell me where i can get a head gasket and ill have to drop the coolant again and spend another 50 dollars
money is hard for me right now
i live of allowance and my parents dont buy me stuff after stuff for my quad
thanks for the help guys
Edited by 350BANSHEE350
if you have only had it for 25 hours, why not take it to the dealer? i think the banshee comes with 3-6 month warranty, they should fix it for free.
if they wont, we will help you out but you have to listen to us. get pictures of the plugs, good pictures. and post them up.
That's true, definately a warranty issue there. Also, what exactly have you done to the bike? I'm guessing it's not completely stock.
yeah it had 3 month warrenty long ago
it has nothing on it for performance it stock
ill get some pics tod
