ok im ridin and poof she over heated so i let it cool down and i look and in my overflow box in the back was empty then i look again and theres black chuncks in it to dark to be dirt
so i look in my rad and there is a bit of coolant and black chunks
im guessing it was my impeller?
i rode it slow back to camp
im guessing i should flush out my rad and hoses and what do i have to do to check my impeller and how hard to change it with a billet one?
thanks alot guys
thanks alot guys
if you pull the cover on the right side of the clutch cover you will see a access pannel to the water pump impeller. you can inspect it there. if its bad you need to pull the clutch cover entirely, if you are going to do that I would recomend installing a billet impeller
Black chunks in your radiator?
Can you tell that they are plastic chunks?
I dont know about everyone elses but, my stock impeller isnt
black.
Id drain all that crap out, fill it with water, start it and look in the radiator
to see if the water is circulating.
MIght wanna check your compression to see if you blew a head gasket too.
:beer:
ok well it only has freakin 25 hours on it cuz its an 07 it runs great no extra smoke and no leaks around the head
ill check my impeller tomorrow
does that little coolant reserve allow coolant to be drawn into the rad also? i figured that it was only and overflow box not an extra intake for coolant
if it dosnt withdraw coolant inot the rad then its a blown gasket
thanks guys
ok here are some pics
i got a sample and it is very thin and almost rubbery kinda weak and a bit of a shine to them
i have no clue what this might be but there is quite a bit of it
cant really see but far right corner there is a pool of it
Are they plastic pieces did you look real close at them? I would go ahead and drain your fluid out real good, flush all the gunk out. Go ahead and get a 60 dollar billet impeller for insurance purposes so you won't have to worry about this again. I'm waiting on my billet impeller to come in as we speak to put it on this week. Just make sure you don't get any air pockets in your line when refilling your radiator back up with coolant. There are two bolts on the side of your jugs that your suppose to unscrew and when coolant starts to flow out the bolts tighten them so you get all the air out. It helps my buddy blew his up cause he didn't do that.
I just wrote on a the previous thread bout this.
Think it's the coating on the copper head gasket.
Remove the hose from the head where leads to top of radiator.
Remove rad cap an run hose, don't forget to disconet line to overflow bottle. Should rinse it all out.
Stock impeller is white plastic if I'm not mistaken!
so is it bad for the copper coating to come off should i get a new one?
i think it might be from a hose that scretched from the heat and flaked a little because if you feel the inside of a hose its smooth and shiny bu ti dont know as much as some of you guys
how hard is it to install a billet impeller?
If you believe that it is the impeller than just take a look nothing realy to it. I doubt it is the impeller though considering its a 07 I dont think it would take a shit on you this soon. I too think its the head gasket material coming off. let us know what you find out.
I thought the stock impeller was green? at least mine was :shrug:
That black material is most definitly the coating on the head gasket... when i was replacing mine after taking a peek at the top end, lots of that black stuff came off on the jug surface... and it was exactly as you described
well i am gong to check my impeller today but since its probably the head gasket is it bad oris that normal?
to flush the bike im just going to run a hose threw the rad with the cylinder bolt off then put them in start it and do it again until clean
well thanks for the help guys
BTW if it was a copper material coming from the gasket wouldnt it be copper not black?
well i drained it all out there was alot, my impeller was fine but im almost thinking that the chuncks were over spray that wore off from it getting hot because its thin and flaky like paint
thanks guys
