banshee parts
ok so i sorted through most of the stuff i have and here's all i found. might have a few more things so ill post em if i find em too.
i have a freshly reupholstered seat (with the latch) j-arm type frame (no paper wor but numbers are clear. i had em checked) full coffman pipes and silencers, front calipers, rotors, spindles and hubs, lower arms, stock stator with timing plate attached, wiring harness, control switches, stock thumb throttle, coils in good condition with wires, stock gas tank with petcock valve and gas cap (no leaks), and i also have a recent edition new Clymers manual for the banshee, six-pac chrome cooler rack, new in package (+4* degree key), stock crank with rods, (one rod has a bad bearing but otherwise in perfect shape!) polished lower rear linkage bone...
i also have a set of new gecko sand paddles. one trip on them. i had an accident and punctured a sidewall but i bought a replacement one so it needs to be installed. tires are installed on ITP wheels. one of the wheels has a dent on the inside of it from the accident tho nothing bad. forgot the size.. ill check on it tomorrow when i have light.
i can get pictures of what you are interested in. PM me your request, ill reply with a "yes i have it" a picture and a price and work from there. just dont waste my time asking for stuff if you dont really wanna buy it. lets work out a deal. flexible on prices. parts located in san diego CA.
NOTE ON THE FRAME: frame is just to big to ship. past few quotes i had for people neared 80-100 dollars just to ship it, so its really not worth me shipping it. however if you absolutely need it and you are cool with a potentially high shipping price and still see fit paying me for the frame, ill look into shipping for you. OTHERWISE the frame is local pickup PREFERED!!
PM sent for the rack
PM's returned to everyone. thanks.
payment pending on linkage and rotors.
clymer's manual pending.
forgot to mention this earlier but ill throw this ou there just in case. id also trade parts for 400ex parts depending on what you have.
k. i guess i need to list some prices in order to move this stuff so here goes. pm me on what you are intrested in. first come first serve.
stock stator with timing plate - $50 bux
reupholstered red seat off a 91- $50 bux
j-arm frame no cracks, bends etc.- $40 bux
coffman full pipes and silencers- $100 bux
front calipers- $25ea. or $40 for both
front hubs- $20 for both
front spindles- $20 for both
lower front a-arms- $20 for both.
wiring harness- $15 bux
control switch- $15 bux
ignition coil- $25 bux
stock thumb throttle- $10 bux
gas tank with cap and petcock valve- $30 bux
nip 4* degree key- $15 bux
nip boysen power reed pettals- $30 bux
stock crank with bad lower rod bearing- $30 bux
what year is the harness from?
any splices or repairs?
shipped to 60436?
shipped to 60436?
harness is from a 91. as for splicing, the only thing that was done is the ignition key wires were placed together to get rid of the key. otherwise its fine.
usps priority is 9 bux. 25 shipped its yours.
was looking for a 96 or newer harness thanks for your time though
ok, no problem
wallace84 - currently waiting on a guy to answer back from the shipping quote i sent him. ill let you know if he bails. till then sale pending on the rack.
ok, no problem
wallace84- rack is back up for grabs. PM me.
deal pending on stator, calipers, wiring harness, front master cyl, and switch pannel.
Edited by alisn4x4
just an update- i now have some front red lable douglass aluminum wheels. no dents bends etc.. these wheels have the reinforced outter ring. i also have some 21x11x10 gecko sand paddles on ITP wheels. one wheel has a minor dent on the inside portion of the wheel but nothing that caused any vibration. one tire has a sidewall puncture so i bought a new tire to replace it. tires and wheels have 2 trips on them.
gecko 21x11x10 on ITP wheels - 80 bux
front red lable reinforced douglass wheels yamaha bolt pattern - 50 bux
cylymer's manual SOLD
stock stator with timing plate - $50 bux pending
front calipers- $25ea. or $40 for both pending
wiring harness- $15 bux pending
control switch- $15 bux pending
stock thumb throttle- $10 bux pending
