lt250rfd
1 Follower
About lt250rfd
  • Birthday 06/22/1982
Contact Methods
  • Website URL
    http://
  • ICQ
    south subs, illinois
  • Interests
    beer, sleds, quads, ff, more beer
    1996 banshee red/black k&n pods pro circuit platinums **sold** 1995 banshee purple/yellow fmf fattys w/powercoreII with some other aftermarket.
lt250rfd's Achievements
HQ Soldier
HQ Soldier (2/5)
  1. no havent had chance to get out there with work and family hopefully can mess with it this weekend. if dont have anything going and get those parts back for that bike let me know can wrench on them in the garage.
  2. Are you talking the pancake bearing and the push rod? those are free. the gear on the back side of the clutch basket is still intack with the shaft and spacer and thrust washer. my guess is its seized and or welded and may be the issue. just unsure on how to remove with out prying. gonna try to mess with it later tonight.
  3. need some suggestions/help on clutch issue. shee runs fine but no clutch. has pressure on clutch handle like should, so checked and reset all adjustments but no go. replaced cable thinking had stretch as well as plates and springs but still same issue. so pulled basket plates etc... has anyone had problem with washer and or spacer seizing or welding itself to gear behind basket? to me thats where the problem lays but not sure. gear is still on shaft end as well as spacer and washer. now wondering how to pull gear washer spacer etc... with out prying or breaking anything. snapped a few pics but no luck uploading. any help or advice would be great. thanks, joe. link to a few pics http://imageshack.us/g/404/dsc02014m.jpg/
  4. Thanks that is what im looking for, more so the electrical section but can make do. Hopefully I can get it figured out. Thanks again, Joe
  5. like the title says, looking for a manual for a 2003 50cc polaris. actually just looking for the electrical specs in it. my daughters quad lost spark so looking to test components.
  6. saw this one on cl chicago http://chicago.craigslist.org/nch/rvs/2974574037.html
  7. insurance and keep it put up when not in use. scumbags around my area will go by with camara phone and take pics of open garages than get bigger pic on pc to see what you got and what to get.
  8. everything sold but secondary clutch, oil resi/airbox, and some radius rods.
  9. Sounds good, won't be riding until sled season over. Cool, all good. Well depends, some times a few and other times 10 plus depending on where we go riding. Been riding trails in northern wisc by families property with big group. Usually try to hit up badlands, cliffs, or fox valley a few times a yr. Use to ride the dumps and casino area before started cracking down.
  10. actually in rockdale so not far from manhappening
  11. What is left: Heat exchangers, flywheel, chaincase, wiring, expansion chamber, red plastic ski (does have damage), driveshaft, steering stem with rods, intake boots with crossover, gas tank shroud, fuel pump, snow flap,headlight, brake rotor, rear bumper cover, park brake lever, top half or airbox, chaincase dipstick, steering rod, caliper for parts, misc. coolant hoses, ski bump stops, pulse coil, voltage sensor, water pump. Also have a hood and rear skid. Hood has damage but is usable. Skid has seen better days and could be used for parts or rebuild. All parts located in Il, south suburbs of chicago. Have pics if need.
  12. What is left: chaincase cover, new windshield polaris #2874612, mirror, exhaust grommet, hood plenum, steering stem, drive/jack shaft, brake rotor, cdi, voltage regulator, some wiring (hood section and short cdi piece), y-pipe, 13 plate hyvo chain, handle bar clamp, handle bar pad, drive cog, steering boots, rear bumper covers, handle bars, coolant bottle, hood strap, ski bump stop, throttle cable, secondary clutch, ski spindle, steering stem bushings and keepers, misc. hardware, drive/jack shaft flange. All parts located in Il, south suburbs of chicago. Have pics if interested in something and have paypal.
