alisn4x4
Everything posted by alisn4x4
BUMP on what i gots left! stock stator with timing plate - $50 bux pending reupholstered red seat off a 91- $50 bux obo j-arm frame no cracks, bends etc.- $40 bux pending coffman full pipes and silencers- $100 bux obo front calipers- $25ea. or $40 for both obo front hubs- $20 for both obo front spindles- $20 for both obo lower front a-arms- $20 for both. obo wiring harness- $15 bux obo control switch- $15 bux obo ignition coil- $25 bux obo stock thumb throttle- $10 bux gas tank with cap and petcock valve- $30 bux obo nip 4* degree key- $15 bux obo nip boysen power reed pettals- $30 bux obo stock crank with bad lower rod bearing- $30 bux obo reminder guys, if you could do me a favor when sending me MO's, please attach a note saying what all you bought and your online screen name. helps track down evryone's parts faster. thanks.
:::::UPDATE::::: im taking offers on all these parts. within reason.... im not giving stuff away but the more you take the better the deal. gecko 21x11x10 on ITP wheels - SOLDfront red lable reinforced douglass wheels yamaha bolt pattern - 50 bux PENDING cylymer's manual SOLD stock stator with timing plate - $50 bux reupholstered red seat off a 91- $50 bux j-arm frame no cracks, bends etc.- $40 bux coffman full pipes and silencers- $100 bux front calipers- $25ea. or $40 for both front hubs- $20 for both front spindles- $20 for both lower front a-arms- $20 for both. wiring harness- $15 bux control switch- $15 bux ignition coil- $25 bux stock thumb throttle- $10 bux pending gas tank with cap and petcock valve- $30 bux nip 4* degree key- $15 bux nip boysen power reed pettals- $30 bux stock crank with bad lower rod bearing- $30 bux reminder guys, if you could do me a favor when sending me MO's, please attach a note saying what all you bought and your online screen name. helps track down evryone's parts faster. thanks.
picture sent. to the rest, all pm's have been replied to. TLONG- what all do you have?? im not in need of too much at this point but always on the look out for things i may think i need. :happy: joneser-, thanks bud. :::::UPDATE::::: gecko 21x11x10 on ITP wheels - 80 bux PENDING front red lable reinforced douglass wheels yamaha bolt pattern - 50 bux PENDING cylymer's manual SOLD stock stator with timing plate - $50 bux reupholstered red seat off a 91- $50 bux j-arm frame no cracks, bends etc.- $40 bux coffman full pipes and silencers- $100 bux front calipers- $25ea. or $40 for both front hubs- $20 for both front spindles- $20 for both lower front a-arms- $20 for both. wiring harness- $15 bux control switch- $15 bux ignition coil- $25 bux stock thumb throttle- $10 bux pending gas tank with cap and petcock valve- $30 bux nip 4* degree key- $15 bux nip boysen power reed pettals- $30 bux stock crank with bad lower rod bearing- $30 bux hey guys, if you could do me a favor when sending me MO's, please attach a note saying what all you bought and your online screen name. helps track down evryone's parts faster. thanks.
thanks. anytime man. glad to be o help.
bump for the rest of these parts!
just an update- i now have some front red lable douglass aluminum wheels. no dents bends etc.. these wheels have the reinforced outter ring. i also have some 21x11x10 gecko sand paddles on ITP wheels. one wheel has a minor dent on the inside portion of the wheel but nothing that caused any vibration. one tire has a sidewall puncture so i bought a new tire to replace it. tires and wheels have 2 trips on them. gecko 21x11x10 on ITP wheels - 80 bux front red lable reinforced douglass wheels yamaha bolt pattern - 50 bux cylymer's manual SOLD stock stator with timing plate - $50 bux pending reupholstered red seat off a 91- $50 bux j-arm frame no cracks, bends etc.- $40 bux coffman full pipes and silencers- $100 bux front calipers- $25ea. or $40 for both pending front hubs- $20 for both front spindles- $20 for both lower front a-arms- $20 for both. wiring harness- $15 bux pending control switch- $15 bux pending ignition coil- $25 bux stock thumb throttle- $10 bux pending gas tank with cap and petcock valve- $30 bux nip 4* degree key- $15 bux nip boysen power reed pettals- $30 bux stock crank with bad lower rod bearing- $30 bux
wallace84- rack is back up for grabs. PM me. deal pending on stator, calipers, wiring harness, front master cyl, and switch pannel.
ok, no problem wallace84 - currently waiting on a guy to answer back from the shipping quote i sent him. ill let you know if he bails. till then sale pending on the rack.
harness is from a 91. as for splicing, the only thing that was done is the ignition key wires were placed together to get rid of the key. otherwise its fine. usps priority is 9 bux. 25 shipped its yours.
k. i guess i need to list some prices in order to move this stuff so here goes. pm me on what you are intrested in. first come first serve. stock stator with timing plate - $50 bux reupholstered red seat off a 91- $50 bux j-arm frame no cracks, bends etc.- $40 bux coffman full pipes and silencers- $100 bux front calipers- $25ea. or $40 for both front hubs- $20 for both front spindles- $20 for both lower front a-arms- $20 for both. wiring harness- $15 bux control switch- $15 bux ignition coil- $25 bux stock thumb throttle- $10 bux gas tank with cap and petcock valve- $30 bux nip 4* degree key- $15 bux nip boysen power reed pettals- $30 bux stock crank with bad lower rod bearing- $30 bux
forgot to mention this earlier but ill throw this ou there just in case. id also trade parts for 400ex parts depending on what you have.
clymer's manual pending.
PM's returned to everyone. thanks. payment pending on linkage and rotors.
ok so i sorted through most of the stuff i have and here's all i found. might have a few more things so ill post em if i find em too. i have a freshly reupholstered seat (with the latch) j-arm type frame (no paper wor but numbers are clear. i had em checked) full coffman pipes and silencers, front calipers, rotors, spindles and hubs, lower arms, stock stator with timing plate attached, wiring harness, control switches, stock thumb throttle, coils in good condition with wires, stock gas tank with petcock valve and gas cap (no leaks), and i also have a recent edition new Clymers manual for the banshee, six-pac chrome cooler rack, new in package (+4* degree key), stock crank with rods, (one rod has a bad bearing but otherwise in perfect shape!) polished lower rear linkage bone... i also have a set of new gecko sand paddles. one trip on them. i had an accident and punctured a sidewall but i bought a replacement one so it needs to be installed. tires are installed on ITP wheels. one of the wheels has a dent on the inside of it from the accident tho nothing bad. forgot the size.. ill check on it tomorrow when i have light. i can get pictures of what you are interested in. PM me your request, ill reply with a "yes i have it" a picture and a price and work from there. just dont waste my time asking for stuff if you dont really wanna buy it. lets work out a deal. flexible on prices. parts located in san diego CA. NOTE ON THE FRAME: frame is just to big to ship. past few quotes i had for people neared 80-100 dollars just to ship it, so its really not worth me shipping it. however if you absolutely need it and you are cool with a potentially high shipping price and still see fit paying me for the frame, ill look into shipping for you. OTHERWISE the frame is local pickup PREFERED!!
yea... i see what yer talking about now.... money is being refunded.
2smoker- i dont think i got your PM.
bump. still have a few parts. 1 set of pipes, all the ignition parts including the stator and timing plate, vito's advance key new in the package... i think i may also have a flywheel puller? that and also have a near new clymer's manual for the banshee.. PM me. tell me what you need, ill tell you if i have it. also, someone PM'd me a while back about all the body bolts and screws... i finally found em all in a bag, if this was you, pm me back to get your info again and ill send em to you!
bump for the late crew. still got lots of parts laying around. if this stuff dont get picked up soon its all goin on egay.... depending on what you have... i would consider trades on this stuff for 400ex parts as well.
alrighty guys. all PM's returned. looking around i still have quite a few parts around. so far i still have a reupholstered red seat for a 91 with the hinge, j-arm frame clear numbers, stock stator w/timing plate (stock), ignition coil, wiring harness, cdi box, light and kill switch cluster, front brake lever resivoir with handle, clutch handle cluster, 1 full set of pipes, six-pac chrome cooler rack, rear suspension linkage with polished dogbone main link, front (hard) brake lines, and a stock gas tank with valve and gas cap..... and thats just the stuff i sorted through a few minutes ago, not including the other items people are inquiering about. those parts i didnt mention just yet in case they wish to purchase them. so i still have pleanty of items. i just wanna clean out the shed and my pile over at my buddy's house. so PM me or ask what you need ro want, ill see if i still have it and we'll work out a deal. and thanks to all the other members ive made smooth transactions with.
yes, i still have the conversion kit. pm me. joneser4u- i beleive you pm'd me on it. ill get you a price shipped when i get home today. tedd1- told y aman! im glad you like em... hope you enjoy them on your trip and thanks for the buisness. alright. i still have a few items left and im gonna look to liquidate. you want something PM me on it to see if i have it and ill make you a good deal.
thanks guys. glad we were able to help each other out!
BUMP! i still have a few things left... frame, a-arm conversion, pipes, seat, radiator, rear linkage, and so on. taking all offers on this stuff. i need it gone! pm me your offers.
::FATTIES PIPE'S, SILENCERS, AND REAR AXLE SOLD:: still have a bunch of stuff left. nice chrome six-pac rack, wiring harness, and a few other things as listed in the first post. still have another full set of pipes, frame, a-arm conversion new int he box, radiator, hubs, steering stem and other stock stuff.
will do. sushee - did i send you the pictures of the pipes and silencers already? theres a few people i sent em to but dont remember if i sent em to you yet??
bump! frame deal fell through so its back up for grabs. fatties and silencers, axle still pending and motor is pending payment. evrything else is still available. make me an offer on this stuff i need it gone.
