seabass Posted June 28, 2007 Report Share Posted June 28, 2007 I'm wondering if these actually help with cooling, or is this just another boost bottle type gimmick? Quote Link to comment Share on other sites More sharing options...
Klotzban1 Posted October 10, 2008 Report Share Posted October 10, 2008 I run an 18 fin inline cooler on my shee in the return line with a Pro Design high flow water impeller and a coolhead and went from 160-180 down to 120-140 for my running temp. I would say that the inline cooler works some because of the fins, But I wouldn't rely on it soley as a cooler. I installed the inline cooler last after the other mods. Hope that helps you. :cool: Quote Link to comment Share on other sites More sharing options...
Animalman294 Posted October 12, 2008 Report Share Posted October 12, 2008 A 40 degree temp drop with a little piece of aluminum that the water only spends a fraction of a second going through in a hose............ Did you add all the rest of the cooling parts at the same time, cuz that does not sound right............... Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted October 13, 2008 Report Share Posted October 13, 2008 They work great for cutting out a bad spot in the hose and splice it back together. They dont help with cooling. The fins are to thick to disapate any real amount of heat. Sure they shed some heat but not a huge amount. Quote Link to comment Share on other sites More sharing options...
FireHead Posted October 15, 2008 Report Share Posted October 15, 2008 They work great for cutting out a bad spot in the hose and splice it back together. They dont help with cooling. The fins are to thick to disapate any real amount of heat. Sure they shed some heat but not a huge amount. Word. There is also not enough surface area contacting the coolant or the air with those coolers to do a damn thing. :geek: Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted October 15, 2008 Report Share Posted October 15, 2008 The work so good I just got some longer hose and got rid of my radiator all together. :wallbash: Quote Link to comment Share on other sites More sharing options...
