yamahalovr29 Posted June 17, 2007 Report Posted June 17, 2007 OK PEOPLE MY QUESTION IS HOW DOES STOCK BANSHEE CYLINDERS BORED TO 65 MM. COMPARE TO THE CUBS 65 MM. CYLINDERS WHICH WOULD BE 358CC ? I KNOW THE CUBS ARE LIKE A MONO PIECE (MADE TOGETHER). DOES THE CUB CYLINDERS ALREADY HAVE A DIFFERENT PORT DESIGN WITHOUT THEM BEING PORTED?? COMPARED TO THE YAMAHA STOCK PORT CYLINDERS? WHAT IM ASKING IS CAN YOU TAKE A SET OF STOCK BANSHEE CYLINDERS BORE THEM TO 65 MM. AND SEND THEM TO SOMEWHERE LIKE TRINITY OR DUNCAN FOR FULL PORTING AND OUT DO A SET OF STOCK CUB CYLINDERS?? MY FRIENDS PIPED AND JETTED 06 HONDA TRX 450R IS RIGHT ON MY ASS WHEN WE RACE ON THE HIGHWAY WERE PRETTY NECK AND NECK OFF THE BOTTOM AND THRU MIDRANGE..THEN ILL FINALLY PULL AWAY FROM HIM ON TOP END.. MY SHEE IS STOCK BOTTOM END ...STOCK CYLINDERS (NOT PORTED) BORED .040 OVER...WISECOS...COOL HEAD...WITH 22CC PUMP GAS DOMES...RICKY STATOR ADJ. STATOR ADVANCED 5+ DEGREES ....PRO CIRCUIT PIPES AND SILENCERS....STOCK CARBS....MAINS JETTED TO 300...STOCK PILOTS...NEEDLES IN FACTORY SPOT... UNI AIR FILTER WITH AIRBOX LID REMOVED... IM A SPEED FREAK AND WANT MORE POWER THAN WHAT I GOT! ANY OTHER IDEAS BESIDES THE CUBS?? DIFFERENT PIPES? CARB TUNING? BIGGER CARBS? DIFFERENT CC DOMES? ETC...? THANKS GUYS AND SORRY FOR ALL THE QUESTIONS IN ONE FORUM! Quote
jmd0346 Posted June 17, 2007 Report Posted June 17, 2007 From my understanding cubs are more aggressive than the most race ported stock jugs. Again from my understanding you cant port stock jugs as much as the cubs are stock. There just isnt enugh material to work with on stock jugs. Your race with the 450R sounds about right. You should have a definite advantage over him but on the top end only. Get your stock jugs race ported and it wont be a race. Im serious. Its not even worth the effort of the 450R to try and keep up. Thats in a drag race mind you. In the trails the 450R is one of the best bikes on the planet. I dont care how much power you have. I know this because we have a 450R. Against my bike in a drag race its ugly. I mean words cant describe how bad the ass whoopin is. In the trails or track however the 450r really puts on a show. Quote
yamahalovr29 Posted June 17, 2007 Author Report Posted June 17, 2007 From my understanding cubs are more aggressive than the most race ported stock jugs. Again from my understanding you cant port stock jugs as much as the cubs are stock. There just isnt enugh material to work with on stock jugs.Your race with the 450R sounds about right. You should have a definite advantage over him but on the top end only. Get your stock jugs race ported and it wont be a race. Im serious. Its not even worth the effort of the 450R to try and keep up. Thats in a drag race mind you. In the trails the 450R is one of the best bikes on the planet. I dont care how much power you have. I know this because we have a 450R. Against my bike in a drag race its ugly. I mean words cant describe how bad the ass whoopin is. In the trails or track however the 450r really puts on a show. thanks for the reply! yea i know banshees arent as good in the trails...so do you have stock cylinders that have been ported? which port job did ya get..the full drag port? what jetting did ya have to do after the porting? thanks! Quote
BigRed350x Posted June 17, 2007 Report Posted June 17, 2007 HOW ABOUT WE NOT YELL AT EVERYONE FOR THE ENTIRE POST Go do a search. Quote
yamahalovr29 Posted June 17, 2007 Author Report Posted June 17, 2007 HOW ABOUT WE NOT YELL AT EVERYONE FOR THE ENTIRE POST Go do a search. HOW ABOUT NOT BEING A SMARTMOUTH TO NEW PEOPLE HERE!!!! what the hell does it matter if its in CAPITAL or lowercase??? IF IT HURTS YOUR EYES! click the back arrow or the little x up at the top right corner !! I APPRECIATE the comments though! and have a good 1 :biggrin: Quote
strokerace Posted June 17, 2007 Report Posted June 17, 2007 if your going to spend money get the cubs and if your going to get the cubs get a 4mil then race no really get the cubs have them poprted get v-force reeds and35 carbs and shearer drag pipes really make your shee scream Quote
banshee(911) Posted June 17, 2007 Report Posted June 17, 2007 if your going to spend money get the cubs and if your going to get the cubs get a 4mil then race no really get the cubs have them poprted get v-force reeds and35 carbs and shearer drag pipes really make your shee scream do they make 66mm cubs? Quote
alcoholbanshee Posted June 17, 2007 Report Posted June 17, 2007 do they make 66mm cubs? I know they make a 66mm 4mil cylinder. They made it to fit in an under 400cc drag class, so I am not sure if it is available in any other stroke combo. Quote
banshee(911) Posted June 17, 2007 Report Posted June 17, 2007 I know they make a 66mm 4mil cylinder. They made it to fit in an under 400cc drag class, so I am not sure if it is available in any other stroke combo. a 4mill short stroke? Quote
Matt96shee Posted June 17, 2007 Report Posted June 17, 2007 damn dude, you're being the smartass. bigred is a very banshee smart guy....if you would've done a search you would've seen his name 100's of times. IF you would've done a search you would see "Can I run a CUB on the trails" and "How do I jet" are the 2 most over talked about topics. here's where forum mod's would be a good idea...imho HOW ABOUT NOT BEING A SMARTMOUTH TO NEW PEOPLE HERE!!!! what the hell does it matter if its in CAPITAL or lowercase??? IF IT HURTS YOUR EYES! click the back arrow or the little x up at the top right corner !! I APPRECIATE the comments though! and have a good 1 :biggrin: Quote
banshee(911) Posted June 17, 2007 Report Posted June 17, 2007 damn dude, you're being the smartass. bigred is a very banshee smart guy....if you would've done a search you would've seen his name 100's of times. IF you would've done a search you would see "Can I run a CUB on the trails" and "How do I jet" are the 2 most over talked about topics. here's where forum mod's would be a good idea...imho heres what i get doing a search Sorry, an error occurred. If you are unsure on how to use a feature, or don't know why you got this error message, try looking through the help files for more informationoing a search Quote
Matt96shee Posted June 17, 2007 Report Posted June 17, 2007 here's what i get: 10 pages of "Cub Cylinder" related posts. Granted, that's across all forums. "Cub" is too short, I think the min is 4 characters. heres what i get doing a search Sorry, an error occurred. If you are unsure on how to use a feature, or don't know why you got this error message, try looking through the help files for more informationoing a search Quote
