Washburn Posted June 11, 2007 Report Share Posted June 11, 2007 I was rite on my way of putting my new PD Timing plate in when all I could find was a cheap 2:1 screwdriver to get the 3 screws out that hold the stator to the plate and I stripped them round. Any Ideas on how to get these out? I was thinking a left hand bit mabey thatll work. Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted June 11, 2007 Report Share Posted June 11, 2007 Use a dremel and try to grind them flat, center punch them and then drill them out with a bit. Or get an impact driver and a good p2 or 3 bit and whack em out. Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted June 11, 2007 Report Share Posted June 11, 2007 are the screws completly stripped? if not try using an impact driver and get it out. Quote Link to comment Share on other sites More sharing options...
Washburn Posted June 11, 2007 Author Report Share Posted June 11, 2007 are the screws completly stripped? if not try using an impact driver and get it out. I put it all back together running but they are pretty stripped out. I dont think my impact will work. I might try the dremel idea though thats a good one. I hate stripped bolts. I got so good at getting in straight and flush but it never fails on cirten things. Brass screws comeon Yamaha!!!!!!!! Quote Link to comment Share on other sites More sharing options...
RoostRocket Posted June 12, 2007 Report Share Posted June 12, 2007 i dont know if it would work in your case but for most screws ive stripped (mostly float bowl screws on the stock carbs) i used some screw out bits from craftsman they have worked very well for me in the past. and its only like 10 or 15 bucks for the set.... just an idea. Quote Link to comment Share on other sites More sharing options...
blowit Posted June 12, 2007 Report Share Posted June 12, 2007 I put it all back together running but they are pretty stripped out. I dont think my impact will work. I might try the dremel idea though thats a good one. I hate stripped bolts. I got so good at getting in straight and flush but it never fails on cirten things. Brass screws comeon Yamaha!!!!!!!! The impact driver is not to be confused with an air impact gun. The driver device is slick for removing slot and phillips bolts. Grab one from Sears and give it a try. If there is some tooth left, at least you won't steel shavings all over. The other way is to just grind a slot in the head of the bolt and remove it with a slot head screwdriver. I think the impact driver will work great for you though. Brandon Quote Link to comment Share on other sites More sharing options...
2Smoker Posted June 12, 2007 Report Share Posted June 12, 2007 If you can get at it try vice grips. It always works for me, those impact drivers work sometimes, but the one I have you have to hit it and it turns when it gets hit. Things can break that way tho. Just be careful! Quote Link to comment Share on other sites More sharing options...
okbeast Posted June 12, 2007 Report Share Posted June 12, 2007 Grind a slot in it, works every time. Quote Link to comment Share on other sites More sharing options...
theshee Posted June 12, 2007 Report Share Posted June 12, 2007 Yup, take a dremel tool and slot the top so its a reqular screw. Quote Link to comment Share on other sites More sharing options...
CMAC Posted June 12, 2007 Report Share Posted June 12, 2007 Grind a slot in it, works every time. Its so simple its brilliant! Why the hell didnt i ever think of that. :beer: Quote Link to comment Share on other sites More sharing options...
Washburn Posted June 12, 2007 Author Report Share Posted June 12, 2007 Yeah I have the Impact I think Ill try with some needle nose vise grips first if that doesnt work ill give the impact a try at least it will grind more so I can slot it Thanks guys Quote Link to comment Share on other sites More sharing options...
dajogejr Posted June 12, 2007 Report Share Posted June 12, 2007 Yep..grind a slot in it, get a BFS, and tap the end with a hammer. I normally try to tighten them more just a hair, then crack it loose. You'd be surprised how many times you can get it to budge a hair tighter, then it loosens right up... Quote Link to comment Share on other sites More sharing options...
swrbansheeboy Posted June 13, 2007 Report Share Posted June 13, 2007 yea, if you can get to them to hack a slot in them with a dremel use a impact driver with a standard bit. if there so far gone you cant do this trick then just drill off the heads till you can remove the plate then use a set of vise grips to remove whats left of the screws... Quote Link to comment Share on other sites More sharing options...
Fastrat Posted June 13, 2007 Report Share Posted June 13, 2007 I always try a good set of vice grips first, then I'd try grinding a slot. If that doesn't work, drill off just the heads and remove the plate, leaving a nice nub to get a vice grip on. Last chance is try drilling it and an easy out. I've used this more times than I can count. GL Quote Link to comment Share on other sites More sharing options...
