mybadbanshee Posted May 26, 2007 Report Posted May 26, 2007 just seein what clutch kits some of you run.and why. Quote
RagunCajun Posted May 26, 2007 Report Posted May 26, 2007 i think mines stock. i run it cuz it works fine. Even with my port job im getting, it will do fine. Quote
EastCoast Banshee Posted May 26, 2007 Report Posted May 26, 2007 Most are gonna tell you get a FAST clutch. Best out there from what i hear. Quote
fastbanshee8 Posted May 26, 2007 Report Posted May 26, 2007 A Fast clutch, a Magnum basket, and a pancake bearing. Great clutch for higher HP, my stock basket was worn, and the pancake bearing will keep the rod, and ball from welding together. I'm also running an E-Z Pull Lever, and perch, because the Fast clutch, with all six heavy springs, is a tough pull. Quote
Devans Posted May 26, 2007 Report Posted May 26, 2007 Like everyone else has said, f.a.s.t. clutch. But ive given hell to my tusk hd clutch and its holding up great, and only spent 40 bucks on it i bleieve. Depends on how much power you are making. Quote
Bansh-eman Posted May 26, 2007 Report Posted May 26, 2007 if your not running a lockup then look into sopme FZR 1000 Fibers and stock steels. if your running a lockup you can pretty much run anything. Quote
mybadbanshee Posted May 26, 2007 Author Report Posted May 26, 2007 can u run a lockup with a stock cover? Quote
RZBansheeMan Posted May 26, 2007 Report Posted May 26, 2007 The stock cover has to be modified. You can do it yourself or have it done, there usually is some "do it yourself lock up kits" on Ebay that include the new center for your stock clutch cover. I am not sure who they are made by though. Quote
Bansh-eman Posted May 26, 2007 Report Posted May 26, 2007 what ^^^he said^^^ also if your running a hinson pressure plate they have a new lockup so you dont have to mod the plate too... Quote
mybadbanshee Posted May 27, 2007 Author Report Posted May 27, 2007 what ^^^he said^^^ also if your running a hinson pressure plate they have a new lockup so you dont have to mod the plate too... ive got a hinson basket but not plate.i think im going to go with the F.A.S.T. clutch. Quote
rocketboy Posted May 27, 2007 Report Posted May 27, 2007 i have found the most important factor for the clutch is the springs .you want heavy duty springs a yz490 clutch is probably the best one yo ucould get for a banshee and still fit inside the basket it is bigger and beefier than even the FZR1000 setup that most guys tell yo uto run or sell you Quote
mybadbanshee Posted May 27, 2007 Author Report Posted May 27, 2007 (edited) i have found the most important factor for the clutch is the springs .you want heavy duty springs a yz490 clutch is probably the best one yo ucould get for a banshee and still fit inside the basket it is bigger and beefier than even the FZR1000 setup that most guys tell yo uto run or sell you you talking about a clutch for a yz490 dirtbike?is this a direct fit?can i use the steels that i have cause they are not worn at all?do you need to use the rubber cushion rings with this setup? Edited May 27, 2007 by mybadbanshee Quote
bansheeyfz Posted May 27, 2007 Report Posted May 27, 2007 I hear that people use R6 clutches in banshees? Quote
RIPPEN Posted May 27, 2007 Report Posted May 27, 2007 I wouldn't fuck with trying to put this with that and that with this.. Just pay the 80-90 bucks for the FAST clutch and be done with it.. If my memory serves me correct I have heard of people runnin that clutch on 4 and 10mill cubs with good results. :shrug: RIPPEN Quote
mybadbanshee Posted May 27, 2007 Author Report Posted May 27, 2007 I wouldn't fuck with trying to put this with that and that with this.. Just pay the 80-90 bucks for the FAST clutch and be done with it.. If my memory serves me correct I have heard of people runnin that clutch on 4 and 10mill cubs with good results. :shrug: RIPPEN thats what i was thinking Quote
