chronicwatson Posted May 16, 2007 Report Posted May 16, 2007 i need to know what parts i will need to put my bottom end back together is there more then just a seal kit or what i need a parts list? any help would be great thanks chronicwatson Quote
nunyabinness Posted May 16, 2007 Report Posted May 16, 2007 yeah i would like to know this as well since that is my next step pulling this rz350 bottom end apart to make sure everything is in good shape. Quote
KaosBanshee44 Posted May 16, 2007 Report Posted May 16, 2007 www.browardmotorsports.com They have any OEM screw, nut, bolt, etc. and complete diagrams of the motor etc. It may help you out as far as how to put it together and what kinda bolts etc. you need. Quote
Screaming Yellow Zonker Posted May 16, 2007 Report Posted May 16, 2007 When I had the case split 2 weeks ago all I bought besides the stroker crank was a seal kit from Vito's, a clutch cover gasket, and some 3 bond (or you could use yamabond) The sealant I got was $17 a tube. It is designed for 2 strokes because it wont hold the case up the 1-2 mm others might. (So I was told) You might need base gasket and head gasket as well. The only other thing I bought was trarry fluid. Quote
Bansh-eman Posted May 16, 2007 Report Posted May 16, 2007 i will assume your putting in a new crank and everything... you can get a seal kit for all the seals for the crank, tranny, impeller, kicker ,shift shaft, youll need new clutch cover seal base gasket and gead gaskets, youll need some yamabond for the case halfs. a torque wrench clutch holding tool and flywheel holding tool. there might be more but thats what i remember off the top of my head... Quote
