chronicwatson
    blue 01 bandit fronts,fast trekker backs,and race cut fenders, the rest is stock
Recent Profile Visitors
1,248 profile views
chronicwatson's Achievements
HQ Soldier
HQ Soldier (2/5)
  1. 50-1 is less oil then 32-1 so it would smoke more with 32-1 than 50-1
  2. Sutton, Ontario pits, trails, dirt roads 01 shee
  3. i want the pipes, front rims and tires, and the billet impeller, i'm in canada so the shipping will be cheaper if you will sell me these parts please pm me prices and your pay pal info thanks chronic watson
  4. well any way i want to make it so i can turn just my high beams on and off i see a blue and yellow wire going to the swith then a green wire goes to the lights and a yellow go to the light any way if any of you could help that would be great thanks
  5. ya it wasn't going on right and i thought maybe i need eight but then i got it on and the hd springs make the clutch nice and stiff
  6. hey man thanks alot i already got it but now i know for sure thanks alot chronic watson
  7. i want to know if i can run seven plates with my hinson basket it looks like i may need eight i'm not sue any help would be great thanks
  8. is the inside smooth or is there little notches it looks smooth
  9. come on guys some one has to know what way the right way is ?
  10. i'm in the middle of putting my engine back togeather and i'm not sure what way the seal on the fly wheel side of the crank goes in it's not a yamaha seal so there is no green marking to tell me what side is what. the one side has a fatter lip with letters and numbers on it and little ridges in the center. The other side has a thinner lip with no letters or numbers on it but the center is smooth with the bearing info on it if any one can help me with this i need to know what way it goes in plz help me. chronicwatson
  11. should i use the RTV on both sides of the base gasket or just on the top or bottom and should i use the honda bond i heard that it was better plus there is only a honda dealer in my town. Canada sucks for getting parts and shit thanks chronicwatson
  12. i did the test with 6 pounds of air and i sprayed the whole motor with soapy water and there where vary small bubbles comein out of the base gaskets. what should i use to seal the case's is flange sealent good?
  13. yes i found a leak like stated above is it RTV copper gasket
  14. on both sides of the gasket or just the tops and what is rtv really called?
  15. i just put my new top end together and when i was done i did a leak test and it failed so what i want to know if it will be ok to put some flange sealent or rtv on the gaskets i don't want to have to buy 3 set's of top end gaskets so if this will help stop the leaks that would be great oh ya they where a metal/paper type any way thanks for any tips thanks
