350BANSHEE350 Posted April 12, 2007 Report Posted April 12, 2007 i started up my shee today and let it warm up till the pipes were warm and i went to just drive it up my driveway and into my garage (20 feet to get it in)and half way there it made like a fluff pop fart kinda sound and so i went back down the driveway and it did it again i didnt even put much work on th motor because i was using the clutch alot i did turn the TORS screws up 1 turn, would i need to rejet for that? it is only 2 degrees celcius outside and i can see my breath so im guessing thats the problem BTW my bike is all stock the only thing i did was the TORS screw thing just wanted to make sure that nothing is wrong with it before i take it out on may long weekend thanks for any advice Quote
yamaha04 Posted April 12, 2007 Report Posted April 12, 2007 wtf are tors screw. im guessing you mean the idle screws on the top of your carbs in the big ass tors unit. try a new set of plugs sometimes then foul out over time more so when you mix your gas with alittle extra oil. if new set of plugs dont work jetting could be the issue because of the cool weather. but ry some new plugs. Quote
Michael Jackson Posted April 13, 2007 Report Posted April 13, 2007 farting noise huh..? must be a 4 stroke Quote
derfnigel Posted April 13, 2007 Report Posted April 13, 2007 sneeze could be carbs out of sync or a little lean if it was jetted for summer Quote
