Call a builder, here's a quick run down.
Head, coolhead or stock, cut to run big bore pistons.
68mm blaster pistons.
10 mil cub casting/cylinder
10 mil stroker crank
cases trenched so the crank rod journals don't rub
That's the necessities....here are the recommended.
Override trans, dunable or standard.
Lockout clutch (a must pushing 110 to 125HP)
Big Bore Pipes
Larger carbs, 35 to 41mm
Longer Swinger
extended chain
That's a basic list...
A stock motor pushes 35 HP, give or take. that motor will make roughly 4 times that.
How reliable it is depends on how well it's put together and how well it's maintained.
Bottom line is is a drag engine....so...there are no real guarantees...period!
Well stated Dave, plus the bottom line is what you are ultimately going to do with the bike and how much money you want to spend. Everything on a 7 or 10 mill has to be changed because of the design of the motor, which is one of the reasons for designing the cub, because it uses a majority of the parts that you already have.......................
Good luck with your decision. :evil:
ive had my 10mm cub for over a year now. its been reliable as fuck and runs hard..ive never had any issues with it. they are pretty expesive to build from scratch. what you gonna use it for? a 4mm cub really has plenty of power for most applications..
noss head 21 cc domes
39mm pwk
vf3
straight cut gears
2-4 duneable override
rocket pipes
lockup
Big Bore Pipes
Longer Swinger
extended chain
pretty much nailed it there!!
I will be using the motor mostly for drag racing and a little dunning. Ihave a cool head and mild drag port now, and would like to see a night and day difference with the new motor. I was also looking at a plus 4 but a lot of people are running them around here, and i wanted a bit more power. whats the money difference between the 10 and the 4.
I just ordered 35mm carbs ( used ) supposedly air strikers but we will see. I also ordered all the parts to build a swingarm, as i am a pretty good fabricator and have a dynasty tig welder at home at my disposal. i was wondering how long to make the swinger.
Edited by notatallhappy
10mm are a lot more money.. you have to have the cases trenched. the crank is about 900 bucks. you really need straight cuts to harness all that power.. so right there youre talkin about 800 more bucks easy. you HAVE to run a lockup. and if youre drag racing youlll need an override.. so theres another 600 or so.. theres quite a bit of price difference in the 4mm and 10mm..
Actually...there's a guy coming out with 10 mil forged cranks for not much more than a 4 mil....about 550 was the price I heard.
I'll have to post it up when I find it...
I don't think straight cuts help make more power or not (I've seen claims of 2-3 HP...) but they do relieve side load on the crank itself....so, I'd call that a longevity/insurance factor.
Pipes are a little more...and once you go cub, IMO...a lockup and override are mandatory in my book.
Plus...the cub cylinder 10 mil castings themselves are a little more than the 4 mil.
The price gas used to be pretty big..however, that's starting to change.
