chronicwatson Posted March 23, 2007 Report Posted March 23, 2007 Hi I'm trying to remove the bolt that hold's the cluch boss on by i cant get it to not spin does any one have any tips if so that would be great thanks. Quote
Rustbag Posted March 24, 2007 Report Posted March 24, 2007 they make a clutch boss holder. But I just use the air ratchet. Quote
Ruko Posted March 24, 2007 Report Posted March 24, 2007 I usually use an impact as well but you can also put a penny in the gears to keep it from turning. I had to do that once it worked ok. Quote
mpbanshee Posted March 24, 2007 Report Posted March 24, 2007 Strap wrench and an impact worked well for me. Quote
2004LEBanshee Posted March 24, 2007 Report Posted March 24, 2007 I tried a strap wrench but it ended up not working so I used a towel in the gears worked real good. Quote
FireHead Posted March 24, 2007 Report Posted March 24, 2007 I usually use an impact as well but you can also put a penny in the gears to keep it from turning. I had to do that once it worked ok. This is a potentially risky maneuver. It does work, but if you don't feel comfortable doing it, don't try it. There is a potential to break teeth off gears with this method. :thumbsup: Quote
MDS2106 Posted March 25, 2007 Report Posted March 25, 2007 This is a potentially risky maneuver. It does work, but if you don't feel comfortable doing it, don't try it. There is a potential to break teeth off gears with this method. :thumbsup: The penny is so soft you will cut it in half before you break at tooth.Thats the way we have always done it and you will have no problem.You will still need either some type of tool or you can screw an old clutch fiber and metal together.It is easiest to just use an impact to unscrew it,but be warned if you use an impact to reinstall the nut it is easy to strip out... Quote
MILO Posted March 26, 2007 Report Posted March 26, 2007 if you have access to an impact gun, that's the way to go to break it loose. to tighten it, i put a rag in the gears, which worked great. Quote
