Before you go splitting the cases, check out the carbs. You could just be a little rich on one side. Remove the carbs, clean out all the jets and passages, and check the jet sizes (main jet, pilot jet, and neelde clip position). Put it back together, make sure the carbs are synced, and the air screws are set correctly. Check the reed condition while you are at it. Do a few runs, and see if it clears up, and check your plug colors. It could very well be a crank seal, but check out the carbs first. Crank seals are cheap, but you have to split the cases to replace them.
