2000-banshee Posted March 21, 2007 Report Posted March 21, 2007 is this normal my banshee is spiting a lot of oil out of the exhaust i did a plug chop and jetting is fine here is a pic of it runing for abought a minute Quote
mpbanshee Posted March 22, 2007 Report Posted March 22, 2007 That is a little excessive. What oil to gas ratio are you running? Also, check that oil on the floor. Are you sure it is the premix oil? Quote
2000-banshee Posted March 22, 2007 Author Report Posted March 22, 2007 i am runing 32:1 and it is all premix Quote
mpbanshee Posted March 22, 2007 Report Posted March 22, 2007 Did it just start doing this, or has it always been like that? What kind of silencers? Have they ever been repacked? Quote
2000-banshee Posted March 22, 2007 Author Report Posted March 22, 2007 (edited) it has been doing it sence i bought it last summer and they are stock pipes and silencers Edited March 22, 2007 by 2000-banshee Quote
Snopczynski Posted March 22, 2007 Report Posted March 22, 2007 So what is your oil mixing ratio? Quote
Bansh-eman Posted March 22, 2007 Report Posted March 22, 2007 So what is your oil mixing ratio? he said 32:1 you might need to crack open your silencers and repack them... you running stockers or after markets? Quote
2000-banshee Posted March 22, 2007 Author Report Posted March 22, 2007 (edited) they are stock silencers Edited March 22, 2007 by 2000-banshee Quote
baddsheee Posted March 22, 2007 Report Posted March 22, 2007 they are stock silencers I thought stockers didn't ahve any packing. What if there is plenty of oil in the pipes, just a suggestion to take them out and hae them cleaned with a degreaser. But stills seems too excessive. What is your jetting set at? Quote
jbooker82 Posted March 22, 2007 Report Posted March 22, 2007 maybe you just need to take the banshee out and opean it up. Blow that oil out instead of putting around. :yelrotflmao: Quote
nicktoney Posted March 22, 2007 Report Posted March 22, 2007 one time i forgot to put the pilot jet in the one carb .... i was in to big of a hurry... and it pissed premix out the exhaust like youre seeing.. Quote
2000-banshee Posted March 22, 2007 Author Report Posted March 22, 2007 jetting is a 240 main and pilot is stock and so is the needle and the clip is on the middle setting it has not been opened up sence last summer it has just be started twice this winter would that be some of the problem thanks Quote
Snopczynski Posted March 22, 2007 Report Posted March 22, 2007 I have seen issues with gas welling up in the cases on a banshee, then it has to be taken out and ran pretty hard to get it all out. Quote
EastCoast Banshee Posted March 22, 2007 Report Posted March 22, 2007 Id say clean them things out probably just oil building up. Had that happen on an older KTM250 i had. Didn't help it was jetted rich as a bitch. Quote
2000-banshee Posted March 22, 2007 Author Report Posted March 22, 2007 i thing what is happing is that it is loading up when idling because it is fine for about a minute throttle response is great then starts spiting oil i think all i need to do is run it because it has been siting for all of winter thanks Quote
