2000-banshee
Everything posted by 2000-banshee
  1. i would say that it would be a close race i had a Lt 500 that was piped and ported they definitely shit and get but you have to know how to ride them they are a hole different power band then a banshee if your buddy knows how to ride it he might win
  2. i need some help on jetting for winter right now i am 240 mains no air box lid k&n stock pipes and its bored .20 over elevation is 500-1000 temp would be 35-20 thanks
  3. ya the hole incident is fucked up people don't think before they act think about all the families it effected
  4. i don't know how well the dirt bike lower-end would hold up to 2 more tires because the yfz has stronger gears but other than that it looks sweet
  5. :yelrotflmao: :yelrotflmao:
  6. i took the silencers off and sprayed them out brake cleaner and you should have seen the oil come pouring out then i put them back on and and it was 100% better thanks for the help
  7. what would you guys use to clean out the slincers would a hose and water work or would it rust them
  8. i thing what is happing is that it is loading up when idling because it is fine for about a minute throttle response is great then starts spiting oil i think all i need to do is run it because it has been siting for all of winter thanks
  9. jetting is a 240 main and pilot is stock and so is the needle and the clip is on the middle setting it has not been opened up sence last summer it has just be started twice this winter would that be some of the problem thanks
  10. they are stock silencers
  11. it has been doing it sence i bought it last summer and they are stock pipes and silencers
  12. i am runing 32:1 and it is all premix
  13. is this normal my banshee is spiting a lot of oil out of the exhaust i did a plug chop and jetting is fine here is a pic of it runing for abought a minute
  14. i have a 1989 blaster and have never had a problem with the oil injection system i would leave the oil injection
  15. thanks guys for the help i dont ride in the winter so i am going to jet it for the wamer weather hopefuly it warms up soon :biggrin:
  16. hi there i need some help on jettin i have a k&n air fliter with pro flow plate no air box lid .20 over other than that it is stock my elevation is 500-1000 and temp is 65-75 please help
  17. ya i dont like the stock heal gards i have a set of nerf bars that i am puting on this weekend that i think will look alot better
  18. tell me what you think i took my almost stock banshee and shaved the fenders put on hand gards and a grapic kit now i need pipes this summer before after
  19. thanks for the input i think im going to get the rox ones their only $10 more and the mounting brackets are bad ass
  20. i was thinking of buying a set of powermad hand guards what do you guys think of them durabilty and function
  21. what do you guys think abought pro circuit pipes and slincers
  22. i have 200 mains stock needle and pilots and it seams rich when you look at the plugs they are wet
  23. my elevation is 500-1000ft and the temps are 65-70
  24. hi i need some jeting help i have a 2000 banshee stock except for a k&n air filter outerware no snorkel and pro flow adapter and boured .20 over i live in michigan thanks
