i don't know if this is a rumor or true but, i have heared that the shearer small bore inframe pipes rev so high that you can't shift the bike on a stock trans. the motor is turning such a high rpm that it wont shift unless you let of the gas, so no speed shifting. is that true? does anyone have any on there bike? thanks
Maybe if you double or triple your HP from a stock motor....it ain't gonna shift....
But you can't call the pipes themselves the culprit.
Once you start pushing some real power, some shifting aid is needed...
Any serious drag guy and the more serious duners are putting lockup and overrides in their bikes.
After trying to shift my 421 cub on a stock tranny, it sucked...period.
But my motor put out close to 3 times the HP of a stock bike....
I dont have a problem grabbing gears or speed shifting... but some in experienced rider would say " it wont shift " ....... Yes i run a lockup / stroker of some sort .....& Power shifting is not the problem here , its traction .
- Chase
