BlackBarron
BlackBarron's Achievements
  1. no one needs a banshee how about $2500? i really don't want to put it on ebay
  2. ok my bike has been sitting for about a 5 or 6 weeks and today i stated it up and i let it warm up and then i shifted in 1st and i noticed the bike kinda moved forward, with the clutch in i rev the bike just a little and the bike moved forward. so i thought i would just ride it anyway ( thinking that the oil just needed to cirulate) so i rode it down the road and then i went to a stop and the bile was still moving when i rev it even a little with the clutch in. i know how to adjust a clutch but the thing it, the clutch was perfect last time i rode it. does any one know what could cause this. thanks
  3. RiverSide Racing as in Sabine River. RiverSide Racing is actually a car and truck performance shop. but anyway i an located in Orange, TX thats near Port Aurthor and Beaumont, the zip code is 77630
  4. go here for the pics http://s191.photobucket.com/albums/z306/RiverSideRacing/
  5. Im selling my play bike to start on my triple, i want $3300 and i will help buyer on shipping if needed. anyway here are the mods ( motor has less than 5 hours ride time since rebuild) *MOTOR* cyl. ported by Black Label Racing (play port) bored .040 over new wiseco pistons new hot rods crank and rods (stock stroke) with TZ bearing pro design cool head with 19cc domes billet intakes vforce 3 reeds 2 mikuni tm 34mm carbs k&n filters barrnett clutches with springs FMF Fatty pipes (painted black) pro design timing plate (advanced +5) (Runs on VP 110 race fuel) *FRAME/SUSPENSION* +4 powder coated chromolly swingarm with billet carrier Marvin Shaw Shocks (also have stock ones) custom chrome shifter gearing is 16/42 front and rear stock tires half tread cut front and rear plastics (also have not cut rear plastic) Star chrome grill chrome throttle cover everything else is stock. and here are some pics
  6. im selling my play bike an 2001 yamaha banshee so i can start to build my triple. anyway i would like to get $3300 and i help buyer with shipping if needed. heres the mods *MOTOR* fresh bore .040 over
  7. im selling my play bike an 2001 yamaha banshee so i can start to build my triple. anyway i would like to get $3300 and i help buyer with shipping if needed. heres the mods *MOTOR* fresh bore .040 over
  8. im selling my play bike an 2001 yamaha banshee so i can start to build my triple. anyway i would like to get $3300 and i help buyer with shipping if needed. heres the mods *MOTOR* fresh bore .040 over
  9. +1 on the type f ive been running it for years
  10. probably just some f**ked up shift forks
  11. let me break this down. the closer the top of the piston gets to the dome the more compression, so if you bought a gasket set that had thicker gaskets than that would make that distance between the piston and the dome bigger so you lose compression. :biggrin:
  12. i am thinking of selling my bike to get something faster and i was wondering what to sell it for. 2001 banshee, stock frame, +4 swing arm chromoly tube, (honda style, powder coated black with billet bearing carrier), marvin shaw shocks all around, race cut plastic (blue), motor ported by black label racing, has a fresh bore (.040" over) new wiseco pistons and rings, new hot rods stock stroke crank and rods with tz bearing, pro design cool head with 19 cc domes. billet timing plate advanced 5 degrees. two mikuni tm 34mm carbs, billet intakes with vforce 3's, fmf fatty pipes painted black. barnett clutches and springs and some chrome stuff here and there. motor has 185 psi on both cyl. runs on VP 110 race gas with Castor 927 oil. so whats a good asking price for this bike?
  13. you said that you rebuilt you top end, meaning you changed your gaskets? the thickness of your gaskets will change your compression to. take a piece of 1/8 soldering rod and check the squish. Mine is at .042", you dont want it under .040"
