This is typical with the hinson basket. Pull the backing plate of the back and set it on a flat surface and see if it is bent even a little bit. Hinson uses a cheap backing plate and they bend rather easy. once they bend it will eat cushins all the time. There is a fix you can get a t-1 steel backing plate and the red cushins and it will fix the problem for good.
Where do I get this t-1 steel backing plate?
I'll check that backing plate for sure.
Here is a photo of what I have. I'm also concerned with the gear on it. Looks like it may have some "strange" wear on it. I can only put one picture in here. How do I upload another?
That billet Clutch Basket is a Magnum
I had one in my lt 250r and just remember th way it was written Lt250r like that on it.
I also need cushions and a backin plate so if anyone knows where to get some
i have two hinsons in both of my bikes and none of them say banshee on them..
I am 100% sure that is a magnum
Maybe your does not say banshee on it
Whe would have to look up exactlt what brand that basket is.
Look up close you can see on this one it's written yfs 200 blaster on the bottom
