majicmike
Everything posted by majicmike
  1. majicmike
    NFL Week 7
    BAL @ BUF BAL NE @ MIA NE ARI @ WAS WAS ATL @ NO NO SF @ NYG NYG TEN @ HOU HOU TB @ DET DET NYJ @ CIN CIN KC @ OAK QAK MIN @ DAL DAL CHI @ PHI PHI STL @ SEA SEA PIT @ DEN PIT MNF IND @ JAC IND
  2. The bore size only goes to 75mm. The 75mm needs alot more case work and extra porting to get the ports anywere close. The one in theshee's video has 72mm bore and 4mm stroke. Also has a little extra port work. I that vid That bike is running a 1-5 with 78ro 14 paddle hualers so the mini can be made to run very hard.....But it takes some $ and time as they can be more dificult to tune.
  3. Why thank you! LOL just jacking with you.
  4. majicmike
    NFL WEEK 5
    Week 5 JAC @ KC JAC CLE @ NE NE CAR @ NO NO NYJ @ NYG NYG MIA @ HOU HOU SEA @ PIT PIT DET @ WAS DET ATL @ TEN ATL ARI @ STL ARI TB @ IND IND SD @ DEN DEN BAL @ SF SF CHI @ GB GB MNF DAL @ BUF DAL
  5. majicmike
    NFL WEEK 4
    HOU @ ATL HOU BAL @ CLE CLE OAK @ MIA MIA CHI @ DET DET NYJ @ BUF NYJ GB @ MIN GB STL @ DAL DAL PIT @ ARI PIT TB @ CAR TB SEA @ SF SF KC @ SD SD DEN @ IND IND PHI @ NYG PHI MNF- NE@CIN NE
  6. spindles sold any takers on the bowls
  7. majicmike
    NFL WEEK 3
    NFL Week 3 MIA @ NYJ mia SD @ GB sd SF @ PIT pit BUF @ NE ne MIN @ KC min DET @ PHI det STL @ TB tb ARI @ BAL bal IND @ HOU ind JAC @ DEN den CLE @ OAK oak CIN @ SEA cin CAR @ ATL car NYG @ WAS was DAL @ CHI dal MNF- TEN@NO no
  8. All prices are shipped yfz spindles for you yfz a-arm swap $80 brand new over size bowls for mukunis $130
  9. IMO no Not during the summer when I ride every other week I will change my oil more. But I will not purge every ride. Would I purge a banshee? I think that is some of the resone drag bikes last as long as they do. When I purge I mike the fuel and oil a atleast 20:1 . Some would say thats a bit much but I like the idea for the oil soaking in to the bearings when not riding. But thats just MO.
  10. More E-85 info Fuel injector, carburetor jet sizing, and fuel pump requirements can be estimated by using the following guidelines as a starting point. For a naturally aspirated (NA) engine (carbureted) on gasoline most need a brake specific fuel consumption (BSFC) for gasoline of 0.50 lb/(hp
  11. not so sure about that working on that There have been tests done on non-Flex Fuel vehicles to see if they can withstand the corrosive nature of E85 ethanol. Ron Faget, President of Faget Inc., an Ethanol plant design build firm in Grante FDall Minnesota, ran a non-Flex Fuel 2000 Chevy Tahoe 105,496 miles almost exclusively on E85. He donated the Tahoe to the Lake Area Technical Institute where it was dismantled and studied. They found that there were no adverse effects of E85 ethanol on the engine or the fuel system. In fact, they reported that the engine and fuel system were in better shape than some vehicles that ran gasoline with fewer miles. This video can be seen and verified at . This is my thought on that I would not think so but you may have to drill jets like on methanol. Methanol needs about 87% more fuel e-85 only needs 40% may not even need to drill the jets depending on mods. If you have a near stock bike you may be able to find jets that flow 40% more. But there will be math involved :geek:
  12. I have been watching this thread with much delight. I have be doing reserch on this fuel and decided to put my 700 Raptor( I know not a banshee) on it to see how it would work. I choose my Raptor because ot the tunning ability. I had It set up on methanol (alcohol) and I had a rather large injector 750cc (stock is 450cc). I went back to the stock injector and kept my meth tune. My meth tune was 54% richer than my gas tune with the big Injector. If you are still with me ( I am trying to give the base point for me) so after I changed the injector I knew that I still had some work to do but I was safe. So all of my Reading I found the E-85 needs to be about 30% richer then my gas tune. I am at 54% I am safe so I ride it, It runs good but feels a bit rich. So I return to the truck and lean it 10 % but it still did not feel snapy. So I went to the computer and put it 30% richer than my gas tune and 24% leaner then my meth tune . It felt great but seemed to not be right now. So we did a plug chop and pulled the plug. The plug showed signs of detonation. I went back to the computer and Incressed the fuel by 10% and had the shee ride it. AS SOON as he took off I told ghostrider "thats it" sounded crisp and snapy. Ride Report: It felt every bit as strong as the methanol (ON A FOUR STROKE) and used less fuel than meth. I ran the bike hard. Many hill climbs duning and of course lots of drag racing. No problems hope theshee will see this and post some video of it. It has a smell that......well stinks. The fuel its self made my want to vomit when I worked around it. But with it at $2.09 a gallon and a between 101-105 octane it is a great fuel. I wanted to see what would happen with the fuel and was suprized. It can be made to work in a 4 wheeler and I hope this info helps some one that wants to switch to this fuel. I would start at atlest 45% more fuel and lean down. I will run this fuel in all of my quads and will soon put a banshee on it with the info I gathered today. Hope this helps
  13. Love the looks of them as well little heavy though. but the looks make up for that
  14. majicmike
    NFL WEEK 2
    IND @ TEN IND GB @ NYG NYG CIN @ CLE CIN HOU @ CAR HOU NO @ TB NO BUF @ PIT PIT ATL @ JAC JAC SF @ STL STL MIN @ DET MIN SEA @ ARI SEA DAL @ MIA DAL KC @ CHI CHI NYJ @ BAL NYJ OAK @ DEN DEN BYE 21 (GOT THAT) SD @ NE SD WAS
  15. The guys raptor must have run like crap. Like I said in another post I have yet to find a stock cylinder 4mm banshee to beat mine......Not saying it cant be done just have not seen it yet. I dont use spray yet.
  16. I know this guy has them for 185 shipped nice 3 peice stator cover not polished but easy to do your self. 720-685-8593
  17. majicmike
    NFL WEEK 2
    I bet theshee takes a dick up the ass this weekend. Hey Im jacking up your post You should start crying like your brother!!!!!!!! :yelrotflmao: all in good fun
  18. Why cant these people live around here becuase It would be funny to watch my 14 year old girl on her pink YFZ smoke him. Then to watch her stick out her hand and say "pay up BITCH" :yelrotflmao: I would be diggin sand out of places for week after rollin across the dunes laughing. :yelrotflmao:
  19. majicmike
    NFL WEEK 2
    Are you fuckin kidding me oakland? You dickless cock sucker you are a losser!
  20. A 4mm stock cylinder beat a 10mm cub? where they pushing it ? I have yet to find (I going to start something LOL are you watching dave) A 4mm stock cylinder bike to beat my 700 Raptor :biggrin: and I have been looking. I am not saying it cant be done but havent seen it yet. Any way found this post and have been ROTFLMMFAO :yelrotflmao:
  21. with inframes and on gas it is about right in line. It might not have the extras like stright cuts tz or porting. But it could be built from scratch for half that
  22. sorry mixed you up with andy @ GRR same screen name as on another site LOL sorry about that.
