cbryant_2 Posted February 10, 2007 Report Posted February 10, 2007 A little weird...I just replaced the stator and it started on first kick but then I moved the on/off switch to the off position and it kept running... I only replaced the stator and did nothing else: what would cause this? I am asuming that there is a malfunction inside the switch but could it be anything else? Thanks Quote
r/atvshee Posted February 10, 2007 Report Posted February 10, 2007 try checking if the on/off switch is connected right. Quote
woodro77 Posted February 10, 2007 Report Posted February 10, 2007 mine does that too , the on = off switvh is busted , i just use the key switch Quote
Dinner Posted February 10, 2007 Report Posted February 10, 2007 Mine will only start when on "On" but won't shut off. I took the switch apart and noticed the soldering came apart on some of the connections. So ill just solder them back together :thumbsup: Quote
DUB Posted February 10, 2007 Report Posted February 10, 2007 A little weird...I just replaced the stator and it started on first kick but then I moved the on/off switch to the off position and it kept running... I only replaced the stator and did nothing else: what would cause this? I am asuming that there is a malfunction inside the switch but could it be anything else? Thanks it is in the switch, mine did the samething. just take it apart you will see what it is. Quote
Snopczynski Posted February 10, 2007 Report Posted February 10, 2007 the plastic panel in the switch that holds the contacts probably came out of place, happened to me many moons ago. Quote
