where you using 3/16" or larger fuel line? Did you ever set the float level in the bowl?
Yes, and yes. I tried everything possible to make it work, short of putting a pingel petcock in there, which I know I didn't need for one carb. I'm using the same fuel line on the stockers that I used on the 2 into 1 setup, I just think that the one carb couldn't handle what I was trying to use it for...
  • 1 month later...
  • Replies 63
  • Created
  • Last Reply
Top Posters In This Topic
any suggestions on a 33mm 2 into 1 jetting just installed I have stage 4 pipes K&n no lid v force reeds and jetting now is 3 clip dek /eek I have no Idea 175 main and 52 pilot and it seems to be only running good on the right side MAKES NO SENSE
