CadillacBanshee Posted January 14, 2007 Report Posted January 14, 2007 Im taking the clutch mechanism apart and the ball was welded to the first push rod. How the hell do i take the second push rod out? Its jammed in there pretty good. I tried tapping the engine side was and nothing. Quote
Mike_1978 Posted January 14, 2007 Report Posted January 14, 2007 That same thing happened to me too.. what I did was split the case and remove the gear where the rod goes thru... Quote
kubiac3 Posted January 14, 2007 Report Posted January 14, 2007 Agree, mine was welded inside the gear, I put it in a press and still wouldnt come out. Had to replace the gear shaft. It was around 80 bucks at the dealer ship. Quote
MDS2106 Posted January 15, 2007 Report Posted January 15, 2007 Pop the cluch actuator arm out and dremmel the mushroomed part of the clutch rod smooth.I used a pointed diamond bit on the dremmel and a small pencil sized magnet thru the ball side to turn the rod as needed as dremmling,It takes a little time but I have done it twice with no problems.After all the mushromming has been removed the rod/ball will slide right out with the pull of the magnet.Then you take the magnet and stick it down the clutch arm hole and remove all of the metal filings.Change oil after first ride :beer: :beer: Quote
Bansh-eman Posted January 15, 2007 Report Posted January 15, 2007 mds if you have done this twice you need to either stop getting pulled with your clucth pulled or invest in a pancake bearing lol :biggrin: Quote
MDS2106 Posted January 15, 2007 Report Posted January 15, 2007 mds if you have done this twice you need to either stop getting pulled with your clucth pulled or invest in a pancake bearing lol :biggrin: When I bought my banshee the rod/ball was welded,when I tore it down to change the clutch plates I noticed someone had placed a second ball behind the welded one and adjusted for it.The other time it happened my son's bike ran out of gas at the beach while a friend was riding it, so he got pulled back to the truck about 7 to 8 miles down the beach with the clutch puled in.So i have gotten pretty good with the dremmel in tight spaces.lol Quote
Bansh-eman Posted January 15, 2007 Report Posted January 15, 2007 When I bought my banshee the rod/ball was welded,when I tore it down to change the clutch plates I noticed someone had placed a second ball behind the welded one and adjusted for it.The other time it happened my son's bike ran out of gas at the beach while a friend was riding it, so he got pulled back to the truck about 7 to 8 miles down the beach with the clutch puled in.So i have gotten pretty good with the dremmel in tight spaces.lol haha thats so getto they just added another ball... i didnt even know 2 would fit and still adjust out Quote
BigRed350x Posted January 15, 2007 Report Posted January 15, 2007 Get a ceramic ball... or a pancake bearing... or both! Or learn to ride without holding the clutch in all the time. LOL! Quote
CadillacBanshee Posted January 15, 2007 Author Report Posted January 15, 2007 Where could i get the ceramic ball and pancake bearing? I also need the clutch arm and new pushrods i you guys know where i could get all this for cheap. Quote
Bansh-eman Posted January 15, 2007 Report Posted January 15, 2007 ball and pan cake call jeff.... the push rod and arm get oem from a stealership... Quote
