woodro77 Posted December 30, 2006 Report Posted December 30, 2006 saw a set of 30 mm d slide carbs on ebay , dont know brand , are they any good ? my mods slight porting , +4 timing , v force , k+n , no lid , weisco pistons , fmf fattys any good for my set up ? Quote
djackbanshee Posted December 30, 2006 Report Posted December 30, 2006 Yes d slide carbs are great. Probobly keihins pwk 28 bored to 30 mm great carbs . Quote
jbooker82 Posted December 31, 2006 Report Posted December 31, 2006 They were probable a cheaper Keihin Knock Off. If it were me i would just get the real deal for a couple of bucks more. Nothing like trying to chase down carb or jetting problems and having doubts about the carbs you just bought. Quote
BlazinOne Posted December 31, 2006 Report Posted December 31, 2006 (edited) They were probable a cheaper Keihin Knock Off. If it were me i would just get the real deal for a couple of bucks more. Nothing like trying to chase down carb or jetting problems and having doubts about the carbs you just bought. Can't say enuff about how good these knock offs are.Do a search,I think you will find they are well worth the money. A couple bucks more?Try a whole lot more for exactly the same results.If your into impressing others with your wallet,then go buy the real things. If your looking to impress them with the way your banshee runs,Save yourself some cash and get the 30mm ebay ones.Since there bored 28's,you can use stock boots.If you give him your engine specs,he will set up your carbs and give you extra jets. If your dumb enough to waste your money on Keihns then get ready to dump more into intakes or reed spacers to clear the clutch arm. These carbs use custon bowls with side overflow.The guy is well known and respected in these parts.He specializes in carburation for powersports equipment. Edited December 31, 2006 by BlazinOne Quote
woodro77 Posted December 31, 2006 Author Report Posted December 31, 2006 Can't say enuff about how good these knock offs are.Do a search,I think you will find they are well worth the money. A couple bucks more?Try a whole lot more for exactly the same results.If your into impressing others with your wallet,then go buy the real things. If your looking to impress them with the way your banshee runs,Save yourself some cash and get the 30mm ebay ones.Since there bored 28's,you can use stock boots.If you give him your engine specs,he will set up your carbs and give you extra jets. If your dumb enough to waste your money on Keihns then get ready to dump more into intakes or reed spacers to clear the clutch arm. These carbs use custon bowls with side overflow.The guy is well known and respected in these parts.He specializes in carburation for powersports equipment. i tried to call him from the number on ebay but nobody ever answers the phone ? Quote
BlazinOne Posted December 31, 2006 Report Posted December 31, 2006 (edited) He's usually there from 9-4 weekdays.He spends Sat and Sun out of town tuning the Pro's atvs.He does all the Dyno tuning for Bill Ballance and other top riders,not to mention some pipe manufacturers Edited December 31, 2006 by BlazinOne Quote
