how much is a bad thing. i just tore my motor apart today for the winter to freshin it up to find a hole in my head witch i think in a yamaha defect and my one piston is alittle sloppy in the cylinder. also my rods have some side to side play but no up and down i think this is normal i mean theres not much. what do you guys think?
if you have any play you need to get it rebuilt... on a part that is spinning at 10,000 rpm's the slightest play is intensified tremendously.
yeah the up and down is probably really bad but mines ok that way the hole side to side thing has me wondering i dont think its that much of a gap they down't move much but maybe i will just send the crank away with my heads when they go to Jeff @ FAST.
Edited by yamaha04
Up and down should have no play, side to side play is ok to a certain tolerance. In the ol clymers manual i think it said 2mm of play side to side is the max. My brand new crank from vitos had half a mm play in it out of the box.
yea i agree, because if you have up and down play, that could end up in a piston thru your heads, EEK!
side-to-side is fine(with in tollerance) depending on the matereal of the rod and how it is treated(brand)
Man, I remember my old 87 had crazy side to side play and I ran the piss out of it. Thinking back now... I never would have run that crank now-a-days. I was a poor high school kid though. Ha Ha! Probably helped contribute to my engine blowing up every time i rode the stupid thing. Ha Ha!
I've used cranks in the past that had a little bit of side to side play. (like under .100") one way. With no problems. I don't know an official spec though. Side to side is ok as long as its very minimal, but any up and down play... scrap it!
