smokin 2 stroke Posted November 23, 2006 Report Posted November 23, 2006 ok to dat i was riding bam hear a loud snap chain broke and broke the case but oonly the top part should i worry bout fixin it or no i will get som pic when my pops get home camera in his truck Quote
NYUK Posted November 23, 2006 Report Posted November 23, 2006 if it is just above the front sprocket it is a common occurance. if oil is leaking it needs to be fixed. 9 out of 10 banshees have that chain wack. Quote
HotCarl Posted November 23, 2006 Report Posted November 23, 2006 To protect aginst it happening again you should get a case saver, they are about $20 and prevents the chain from slapping the case. Quote
1.6i Posted November 23, 2006 Report Posted November 23, 2006 To protect aginst it happening again you should get a case saver, they are about $20 and prevents the chain from slapping the case. where can i get one? Quote
HotCarl Posted November 23, 2006 Report Posted November 23, 2006 http://www.motosport.com/offroad/parts.php...0=ATV&nav=4 But I have seen them cheaper on ebay Quote
smokin 2 stroke Posted November 23, 2006 Author Report Posted November 23, 2006 ok heres tha pic hheres my bootleged video lol Quote
CFM Posted November 23, 2006 Report Posted November 23, 2006 Looks like you're cool.. Sucks to have the damage, but if not leaking than just go with it. Can't tell you how many I've had with the same exact damage... Case savers are worth twice the coin they cost. On that note I'm ordering 2 if it is just above the front sprocket it is a common occurance. if oil is leaking it needs to be fixed. 9 out of 10 banshees have that chain wack. While ago I picked up a 92, beat to hell... Could not believe it was not "whacked" Quote
IROOST1 Posted November 23, 2006 Report Posted November 23, 2006 Thats looks like its fine. But get a case saver. The big aluminum one, they are 35 new, and cheaper used. I use a dremel with a cutting disk to cut the case straight and then a sanding disk and it will look nice, not broken. Its a neat trick. Quote
Fre530d Posted November 23, 2006 Report Posted November 23, 2006 To protect aginst it happening again you should get a case saver, they are about $20 and prevents the chain from slapping the case. I have a 17teeth sprocket in front. Will the case caver fit to that? THX Fred :beer: Quote
seabass Posted November 23, 2006 Report Posted November 23, 2006 The cheapest I found is at KD Cycle. It's $23.50 plus shipping for a billet one. It SHOULD fit your sprocket, but don't quote me on that. It is the best deal I found when I was looking. :thumbsup: Quote
1.6i Posted November 24, 2006 Report Posted November 24, 2006 I have a 17teeth sprocket in front. Will the case caver fit to that? THX Fred :beer: at the bottom, it says all of the case savers accept one tooth larger than stock.. check it out http://www.rockymountainatv.com/search.do Quote
David Keith Posted November 24, 2006 Report Posted November 24, 2006 at the bottom, it says all of the case savers accept one tooth larger than stock.. check it out http://www.rockymountainatv.com/search.do NO PROBLEM. Just find a friend who can fly-cut the larger radius required using a Bridgeport mill. Quote
RIPPEN Posted November 24, 2006 Report Posted November 24, 2006 I was running a 13 tooth front sprocket and HAD a case saver.. When the chain de-railed it still bunched up, and bent up the case saver taking out ALLOT of material.. Supose with a 14tooth(which I run now) a case saver may do the trick but be aware if your runnin the 13th. RIPPEN Quote
Ryda85 Posted November 24, 2006 Report Posted November 24, 2006 i believe the biggest sprocket you can run on a case saver is a 15t Quote
Fre530d Posted November 24, 2006 Report Posted November 24, 2006 i believe the biggest sprocket you can run on a case saver is a 15t Damn , so there isn't a casesaver for a 17t :: Quote
