silencethevoice Posted November 12, 2006 Report Posted November 12, 2006 Just wondering if you guys think it's worth breaking my cases apart to weld my crank, or should I check the tolerances and go from there? Need some opinions.. I will list my mods below.. 21cc Domes (170 psi compression) Stock Bore +.020 Eric Gorr Porting FMF Fatties V-Force 3 Reeds +4 Timing Lightened Flywheel Dual 33 PWKs Thanks in advance. Quote
Bansh-eman Posted November 12, 2006 Report Posted November 12, 2006 Just wondering if you guys think it's worth breaking my cases apart to weld my crank, or should I check the tolerances and go from there? Need some opinions.. I will list my mods below.. 21cc Domes (170 psi compression) Stock Bore +.020 Eric Gorr Porting FMF Fatties V-Force 3 Reeds +4 Timing Lightened Flywheel Dual 33 PWKs Thanks in advance. well if you want to be sure your motor dosent let loose then take the few hours to rip iit down and have it welded... id say its a clear answer unless your not worried about your crank separating.. Quote
400ccStroker_shee Posted November 12, 2006 Report Posted November 12, 2006 Just wondering if you guys think it's worth breaking my cases apart to weld my crank, or should I check the tolerances and go from there? Need some opinions.. I will list my mods below.. 21cc Domes (170 psi compression) Stock Bore +.020 Eric Gorr Porting FMF Fatties V-Force 3 Reeds +4 Timing Lightened Flywheel Dual 33 PWKs Thanks in advance. I would weld it!! Quote
silencethevoice Posted November 12, 2006 Author Report Posted November 12, 2006 I would weld it!! I guess I will go ahead and weld the sucker, don't want to have it on my conscience... Can you guys recommend anyone to send it to? Quote
RIPPEN Posted November 12, 2006 Report Posted November 12, 2006 I had mine done from Jeff @ Fast Racing.. His web address is in my sig :beer: RIPPEN Quote
MDS2106 Posted November 12, 2006 Report Posted November 12, 2006 I want to know how you got 170 psi out of 21cc domes.I am at sea level, dune ported with 21cc domes and my compression is 143 in one and 145 in the other cylinder.My compression was up over 150 before porting.My shit must be on the down slide :shrug: Quote
2strokespirit Posted November 12, 2006 Report Posted November 12, 2006 I am a RD/RZ 350 tunner, they were my bread and butter for years, we raced them motors in off road buggies, with motors doing 75 HP we have NEVER weld a crank, if the crank is rebuild more than 3-4 times then i will recommend you weld it. Like i said that is our experience on motors pushing NOT over than 75HP. I have NEVER had one crank come apart in my racing career. But like i said its just my opinoin AND EXPERIENCE. Another opinion http://www.froggy.se/skalmanmc/rd350/index.htm they raced a RD350 with 90Hp on the crank, never welded. Its the same crank that your banshee run with. NB like i said if the crank is rebuild more than 3 times weld it. I have a crank running in a motor whichthe crank has been rebuild 4 times, (70HP motor) in a buggie, no problems at all. But one can only say if the crank will stay together if you rebuild it, depending of how hard it press together if you rebuild it. ONLY MY Experience!!!!!!! Quote
cave Posted November 12, 2006 Report Posted November 12, 2006 Once the crank is welded can you rebuild it or are you going to have to replace the whole deal? Can the spot welds be ground out and then refilled? I waited until until I had my jugs dune ported, lighten flywheel & 36mm Keihin. Now it was time to weld the crank. I opted to have it rebuilt & trued. Quote
Bansh-eman Posted November 12, 2006 Report Posted November 12, 2006 I want to know how you got 170 psi out of 21cc domes.I am at sea level, dune ported with 21cc domes and my compression is 143 in one and 145 in the other cylinder.My compression was up over 150 before porting.My shit must be on the down slide :shrug: i hav a 4 mill and im ony getting 145 also... just some motors sealup better and get alot more compression... Quote
Polish Posted November 12, 2006 Report Posted November 12, 2006 My shee has BB 22cc domes and im getting almost 170psi Quote
silencethevoice Posted November 13, 2006 Author Report Posted November 13, 2006 I want to know how you got 170 psi out of 21cc domes.I am at sea level, dune ported with 21cc domes and my compression is 143 in one and 145 in the other cylinder.My compression was up over 150 before porting.My shit must be on the down slide :shrug: I was wondering the same thing, but as it turns out my cylinders have been cut.. I measured it out today, and one side was cut by 20 thousandths, and the other side was cut by 30 :: Guess you never know what your gonna get when you buy stuff used.. I'm just going to use another set, and while I'm at it I am going to get the crank welded... Just for the peace of mind.. I've had far too much trouble with this bike already and have got to do it right.. Thanks for all the advice. Quote
